Got back on the set a few days ago, and made some progress. Repaired the damaged speaker cone and reinstalled the speaker in place of the temporary filter choke I installed for testing. Repair technique I used is the Tacky glue/coffee filter method Bob Andersen shows on his YouTube channel:
I had to apply my patches on the front of the cone, as the big field coil on a small speaker makes access through the rear of the basket difficult.
Also took a few minutes to reinstall the cardboard covers over all the rebuilt filter caps. they get attached using a thin smear of non-acetic cure RTV sealant inside the end of the tube, and get snapped down over the aluminum can "stumps" on the chassis. This hides all the modern caps completely, prevents a shock hazard from the non-grounded cans, and keeps the topside of the chassis looking original.
Removed my temporary video input circuit and reconnected C103 to the video detector tube. Set my signal generator for a channel 3 signal, and set the tuner to channel 3. As before, no signal on the screen, and no sound from the speaker at any setting of the fine tuning besides a low hum at max volume indicating that the audio amp was alive. Tapping a screwdriver blade on the volume control terminals gave a loud 60 Hz hum from the speaker, so the whole audio amp seems to be OK. So both the audio AND video IFs seem to have no signal coming through them. This would seem to indicate a problem in the tuner itself, before the separate video and sound IF outputs are generated. Tried swapping the 6J6 converter (mixer) tube, and discovered that by wiggling the tube in the socket, the signal would flash onto the screen. We have a mechanical problem, not an electronic one. One of the pins of the tube socket seems to have an intermittent connection. I sprayed cleaner into the socket, and got the set to work pretty well, but the signal periodically cuts out, and thumping the tube or the area around the socket hard brings it back. Looks like I'm going to have to dig into the tuner itself to get a look at that socket and the soldering under it. Unfortunately, working on old time VHF tuners is pretty intricate stuff. the placement of everything affects the alignment, and access to the tube socket terminals may involve a LOT of disassembly on this particular set, as it uses a stack of wafer switches, rather than a single removable turret drum with the coils like many later designs.
I DO have a complete donor chassis, however, with a nice clean tuner assembly. Perhaps a transplant might be the way to go here? Will have to look into it. For now, have the tube wedged in place and working. Sound and picture both tune in correctly, in the same place on the fine tuning control. The alignment of the IF and tuner seem pretty much spot-on after all these years! A multiburst test pattern gives a video response out to ~3.5 MHz, which is typical for a set like this. It improves a bit when injecting video after the IF stages and tuner, as expected. The set is pretty much working, and the screen shots posted here are all from an RF input signal, on VHF channel 3.
Next up will be a modification to make the set more usable in this era now that analog OTA signals are mostly unavailable. Line level A/V inputs and a "line/air" input switch will be installed to allow the set to be fed from a standard composite signal without needing an outboard RF modulator or a repurposed VCR to act as one. Will also pull the tuner from the donor set to see what is involved in the tuner swap or repair decision. Looks like the electronic portion of this restoration is almost complete.
