I'm working on restoring an old Russian (Soviet) computer back to life. Now that computer seems to be in working condition, I needed a way to load programs and games. Originally computer is supposed to load programs from a tape recorder. And tape recorder interface actually works, I tested it with MP3 player and embedded test program. But it is slow and inconvenient.
Additionally there is an interface for external devices. The interface simply exposes MCU bus directly. So I've created a device that connects to this bus and simulates ROM devices, selecting from a number of images stored on the SD card. The hardware is done, but software is not ready yet.
I'm also attaching an picture of one of the standard extension blocks. This one contains ROMs with tests and FOCAL programming language
Now to the trick part. As you can see, this thing is done on a prototyping board with wires. Those are teflon insulation wires. Teflon insulation does not melt under normal soldering temperatures, allowing for precise length control down to 5 mm (1/4"). If you do any prototyping work at all, get some of that wire. It is a bit more expensive, of course, but it is totally worth it. Forget the mess and frustration that melting PVC insulation creates.
The wire used here is from the same era as computer itself, so it is only available in pink (apparently Soviets did not know how to color it). Modern stuff is available in variety of colors.
