Probably, using reverse beta does work on a lot of older designs with low breakdown voltages, though long term it does degrade the device in some cases. Was common on making bipolar devices act as an analogue switch. Crappy switch, horrid performance but was the only solid state relay before CMOS analogue switches were available and if you could not use a Jfet.
As for being unique, it is basically a variant on a old design, the SCR. That is long out of patent though, seeing as it was about the third type of transistor developed, and was ther first one to have really high power capability. Must be at least 100 separate dies made per person in the lifetime,
