First of all, you'll have a much easier time if you work on cleaning up your schematic.
- Spread things out a little more so that all of your wires can be at right angles.
- At the THS7314, why do you have wires terminated at the root of the pins rather than the tips? Are the pins backward in the library?
- No pin descriptors on the BA7230. . .that's just asking for trouble. You want to be able to immediately be able to see if the the components are connected correctly in the schematic, if you have to refer to the datasheet to know what the pins do then you have a much higher risk of mistakes.
- Never run a wire over a component. Either route the wire around from one side to the other, or flip the component to a more suitable orientation.
- Positive power ports should point up, negative or ground ports should point down.
Spending the time to lay out a schematic nicely in accordance with the standards and conventions will not only make it prettier, but more importantly will make it easier for you and other people to read and understand. When it's easier to understand, it's much easier to spot mistakes.
