This is the last post on the project.
Documenting the signals on U2 the RH7050 IC.
The signal names are of course my own invention and so may be misleading.
pin 1,2 & 7 - 0V one or two of these might be unused address code bits set to zero. One is the IC 0V
pin 3,4,5 & 6 REMOTE ADDRESS CODE - An address setting of '1' would be HLLL or switch off,on,on,on
pin 8 OSC & 9 OSC OUT - These pins are connected by R29 160K to set the internal oscillator to 100kHz as measured at pin 9
pin 10 DATA IN - This is the digital version of the serial data from the RF section. It is pulsed from 5V to ground. There is a lot of pulses on this pin even when the remote transmitter is silent.
pin 11 LOW FAN - This 0V signal changes to a 10us 5v positive pulse every 100us when fan LOW pressed. It stays pulsing until FAN OFF or another speed is selected
pin 12 MED FAN - This 0V signal changes to a 10us 5v positive pulse every 100us when fan MED pressed. It stays pulsing until FAN OFF or another speed is selected
pin 13 HI FAN - This 0V signal changes to a 10us 5v positive pulse every 100us when fan HI pressed. It stays pulsing until FAN OFF or another speed is selected
pin 14 NOT KNOWN - This is triangular wave of period 90ms with a low of 2V and a high of 3.5V the wave has a 40ms rise time 50ms and a fall time of. It is still present even without ZCS
pin 15 NOT KNOWN - This is a square wave of period 90ms with a low of 0V and a high of 5V. The signal is 50ms high and 40ms low V. It is still still present even without ZCS
pin 16 FWD/REV- This is 0V after power on then toggles with FOR/REV between 5V and 0V needs ZCS to be functional
pin 17 5V
pin 18 ZERO CROSSING SIGNAL- The ZCS signal is a 20ms square wave having a low of -0.7V and a high ov 5.7V
pin 19 LIGHT DIMMER- This is a series of 10us pulses every 100us. The 5V pulses start 1.5ms (for a bright light) after ZCS edge and always end 8ms after the ZCS. Holding the DIM button causes the start time to change either dimming or brightening the light. A short press of DIM button selects between light off and the previous light intensity setting.
pin 20 POR RESET - This normally hi at 5V it rises slowly (300ms) to 5V after power applied. It is probably the IC reset signal
Probing the IC pins often causes it to hang up and so it may be necessary to power off for a while to get it working again. Don't forget the 5V rail is at mains active potential.
There, I'm finally out of the rabbit hole... will post if anything new develops
I hope that someone finds it useful.
Bob
