I have been enjoying the use of my hacked DS1052E but have been wondering about how to make it more portable and make it an isolated scope. After looking at the schematic made by A Hellene, I started to think it might be possible. But he PSU schematic has a line frequency derived 50/60Hz source supplied to the main board. Any ideas what this might be for?
EDIT: Aha, I see from A Hellene's schematics that this mains frequency signal is fed to the trigger circuit. It is probably a simple way of providing a free run trigger signal. So it probably can be replaced with a simple oscillator to do the same thing.
Beyond this unknown item, there are basically 3 voltages needed to be supplied; -12VDC, +15VDC, and +6.4VDC. The scope also uses has a +3.4VDC supply, but this is derived from the +6.4VDC.
The simple thing to do would be to make an 18VDC battery pack and regulate it down to +15VDC, and then have another regulator to supply the +6.4VDC. Then add a small DC to DC inverter to make the -12VDC. Many parts, much to be concerned about, and a need to switch the battery pack into the existing circuit.
A more simple, but brute force, thing to do is just install a 100VDC battery pack and have it supply the input side of the whole switching power supply. This seem rather inelegant, and dangerous too. I don't like the idea of such a high voltage battery sitting there ready to make a mess of things.
A Hellene's post with his PSU schematic can be found here.
https://www.eevblog.com/forum/index.php?topic=3738.0Any thoughts?
