Hi all.
Going to go over this fairly quickly as it should make some sense and it's almost sleep time (been working on this for 8 hours
We are working on a High-voltage AC or DC to DC power supply, with digital monitoring.
I am using an LTC1966 RMS to DC converter potting down the 900Vac (50Hz single phase) to something sensible, 0.9V. I then have a 1uF averaging cap and a LTC2990 ADC digitising the result. I know the ADC works perfectly fine as I am using this all over my designs with the same code.
The problem I am having: When there is no load on the power supply, at 600Vac input, the output of the RMS to DC converter is all over the place, reading between 300Vac-900Vac. As soon as I put load on the power supply, the converter averages out to the correct voltage +- a few volts...
We have a big-ass filter network on the AC input consisting of more magnetics and caps than you can shake a rusty stick at. I have a feeling this is causing us a few problems as we are measuring after the diode bridge & filtering. I have a seperate circuit measuring just after the diode bridge which is also doing the same thing.
The only thing I can think of doing is increasing the averaging cap (which is a poor 1uF jellybean ceramic) to a 10uF with a different dialectric.
I'll post some more information if I can't get it working tomorrow morning... But hopefully I am missing something very fundamental!
Simplified schematic:
