Ah, of course! Thanks for a great answer!
So in my application, I won't have any mains frequencies, as the product will be run on batteries fairly away from a lot of other stuff. The pre-regulator feeding this is a switching regulator running at 600kHz, so that will probably be one of these frequencies i should control. The subcircuit the RT9025 is feeding I don't really know the frequency of, but it's a HL6528G, a GSM / GPS-modem, so it will have some high-frequency bursts and processing, as well as some lower clock domains like an RTC.
Other places in my application, I'll have some 12MHz stuff feeding into a MCU, and some lowfrequency stuff, but nothing with much current. As such, I don't think this will radiate a lot and be necessary to consider here? What other typical stuff do I need to look at?
So, in theory, I should set the knee frequency of this somewhat below the lowest frequency I want to filter out, but with as small a capacitor as I can get away with and still maintain stability, to maintain good high frequency regulation, right? And the knee frequency is determined by finding 1/(R1*Cf), right?
For the moment, I've put a 10nF capacitor in the schematic, which sets the cutoff frequency at 1kHz. I'm using only 0603 capacitors, so I will be experimentally checking the stability of the regulator with different values if I have to when I get the boards back from the fab.
(Sorry for being a noob about this!)
