2vac is actually the open circuit voltage.
Yes sounds like a better idea to sense the current. So how many ohms resistor should I go with ? Through hole or smd ?
The resistor would go in parallel with one of the cable and two wires form both sides of the resistor the add of the muc, correct ? Would it be a good idea to sense the current during the weld also ?
Www.Georgehobby.wordpress.com
Equipments: DSO104z, Hakko FX888D, Brymen BM869s
Sent from my iPhone using Tapatalk
