Imagine a bicycle hub, turned by a motor. The motor itself is the central axis. Think, slot machine wheel.
Now imagine a linear array of 10, or 25 or 50 of them. If each is an independent assembly, that's a lot of motors.
Now imagine 10 or 25 rows of these arrays. The user can stop or start any wheel via a control board.
I'm thinking, rather than build each individual hub as an independent, self-powered assembly, use a single long axis to power the rotation, and engage each hub to the single powered axis via a gear train. I'd need a bigger motor but overall it's likely more efficient and also less maintenance.
But I would want to stop and start each wheel independently of the others. So, I need some kind of actuator to move a sliding "engagement" gear into place, much like a car's manual transmission engages a gear. Or, instead of sliding along the axis of rotation, it could rotate in from the "edge".
The cheapest linear actuator I could find (in 30s) was Lego Technics at $10. The motor is under $5 so this is a tough sell. The first search results shows actuators in the $50-$70 range. I did find pneumatic ones for $11 right away, but still that feels too expensive.
I feel like the lego part will have enough precision, but not enough long term durability.
Lastly, all the ones I find, even "micro" are actually very long, 5" or more. I don't think that's going to fit well as my hubs are 2" width.
At this point it seems easier to go with independently driven hubs, but wanted to see if anyone has input.
