I'm currently working on two different signal generator designs, the first is a 30MHz DDS based on the Analog Devices AD9834, one minor problem with it is that the internal comparator for generating a square wave has a high pass filter limiting it to >3MHz, I've been thinking of using a TLV3501 comparator with a DAC101S101 to adjust the duty cycle for the square wave.
The output amplifier is still one thing I'm a little unsure of, I'd like at least 10Vpp in to 50 ohms with a wide bandwidth to ensure at least a rise / fall time of 20ns (preferably better), I'm considering doing a discrete voltage amplifier stage followed by a class AB output to minimize cost which is a major goal with this design.
The AD9834 according to the datasheet has some problems with images as the output approaches half the clock frequency so would it make sense to reduce my maximum output frequency to say 25MHz to avoid this (I'm using a 60MHz clock) and include a low pass filter on the output of the DAC (maybe 150MHz to ensure the triangle is reasonable) ?
My second design is a RF generator using the Analog Devices ADF4351 35MHz - 4.4GHz frequency synthesizer, it has a fairly poor frequency resolution of around 8kHz so I've been thinking would it be possible to simply adjust the clock frequency to fine tune it, maybe using the AD9834 along with a nice stable crystal oscillator ?
Any ideas would be very welcome
