After digging for an inductance meter design on the internet and running mostly into the same design using an the inductor under test as part of an oscillator and not liking the idea of using another inductor (not really a precision component) in series with the inductor to be measuresured I decided to design one (read 'I had an idea' ).
now what you think.
... Speaking about precision... My LCF-meter, based on AADE design, quite happily measures inductance from 1uH to about 1H (maybe more) and capacintance from 1pF to about 10uF with quite good precision and linearity. It has probes compensation (did you thing of it, by the way ?).
Can you achieve similar dynamic range with your design ?
If you read the AADE article, you will probably notice, that their design doesn't require _precise_ components, they just need to be stable. Everything else you achieve with proper calibration. On the orher hand, it is quite difficult to provide long-term inductor stability with ferrite core; almost everything affects it, including Earth magnetic field, tempearture, and wires with current near it. It is ok, if I recalibrate my LCF meter every 5 minutes, otherwise it drifts slightly.
