I noticed these little SJ050NA-08A VGA TFT displays are available quite cheaply from a number of sellers, supposedly made by Innolux I've had zero luck finding a datasheet. Has anyone used one of these? Even a pinout would be enough that I could work out the rest, they have a parallel RGB interface which I suspect is the typical hsync, vsync, dot clock, etc but without knowing the pinout or what they were intended to be used in I'm pretty much stuck.
