New project and a few questions concerning the oscillation frequencies.
Here's the website for this project
https://translate.google.ca/translate?hl=en&sl=hu&u=http://skory.gylcomp.hu/tesla/mini_tesla.html&prev=search .I used google translate since I can't read Hungarian.I did my best to translate the most important descriptions the circuit diagram.
Ok The frequency at the 555 is only around 70 Hz. Which seems low for driving T1 and T2 Mosfets .They get pretty hot even with heat sinks .Of course more heat sinking will be required later but for short tests what I have should do for now.The transformer is a 2:1 but only 11/22 winding's not the prescribed 15/30 .
My coil is different from the original.And the circuit only pulls around 2.5 amps at 13.8 volts.I'm running the PSU in Parallel for 10 amps .
Now I figure my primary coil should run around 78 kHz not 70 Hz that would put the secondary coil I have at around 505 kHz and the C4 ,L4 oscillator from the example is 400 kHz .These are estimates
Should I kick the 555 to 78kHz and the C4,L4 oscillator to 505 kHz.Or am I looking at this wrong .
The circuit works sort of but not as good as what it could be .
Pardon the mess and lighting .I'm still in the process of wiring my lab .And don't make fun of my toroid .Took me all day to make that .I'll make a better one later.
