I need a DPDT On-On (or On-Off-On) rocker in a panel.
All the rocker switches that I have found are quite big: about 25 mm in width. Is there something smaller around?
I am looking for name brand switches and I need to switch low voltages (< 24 V) and low currents (< 1 A). The switches are to be mounted with a snap-on mechanism onto the panels. All I have found are big chunky switches with six 6.3 mm fast on connectors. I understand that they need to be so big to reliably switch 10 A @ 240 V AC, but I don't need that.
DPST and DPDT On-Off switches can be found in the more compact 15 mm width version. Aren't there similar switches for DPDT?
