I did but I am greeted by price tags of at least 400$ for a very simple probe.
I mean like little sensor heads I can embed into stuff, like drill a hole in the chassis, run a wire (or run it through a air duct etc) and connect it to a DAQ. I want alot of these things.
After its all closed up and stuff.
The device with a hand held part is just gonna be useful for calibration and taking vent measurements. I wanna see whats going on inside. I was hoping there was a engineered kit for this kind of thing that I can mimic.
Like you know how you epoxy a bunch of thermocouples to various parts/chips in a system, put it back together, then take measurements on them while its running? I want to do that with air.
Or to even embed sensors into my product, so I can have a 'vent blocked' or 'insufficient air flow' or 'change filters' setting, it makes sense to do it with a ducted fan IMO. I don't like axial fans anyway.
I was hoping for some standard solution like with RTD's and thermocouples, where you have a standard form factors, accuracy classes, linearization equations (like calsen van dusen polynomial for RTD or whatever), mounting solutions, etc.
Like a thin-flm class B rtd meant for measuring up to 200C is a 'standard' part between manufacturers pretty much. Once you seen one you know how the electronics and mounting for it are gonna go, and you know there will be standard options like 2wire, 3wire, 4wire, etc.
Or 1/4 inch NPT thread class A rod thermocouple (i.e. you can find similar parts from every manufacturer, like Omega).
I know there are metrological solutions for all this stuff, like a 10ohm 4000$ RTD, but I am just looking for stuff that you would equate to like standard thermocouples, surface mount RTDs, etc... that everyone in the industry is gonna be familiar with.
