You need to grab it with tweezers anyway, to place it on the PCB??? I dont know about the quality, these are like a year old, and I havent used them "in action" they just look neat, and I thought I share it.
Fair point! The few times I've done any SMD soldering though, I've always felt the need to place the part(s) I'm about to solder on a small flat tray first, so I can have a look at it under the scope, find the right orientation and then move it from that tray onto the PCB while looking through the scope. It may be that with practice I won't need this security blanket and can go straight from bin to PCB. 0402s are pretty damn small and fiddly though, at least to my imperfect eyes! I do like the look of those boxes you posted a photo of, in fact they were on my list until I saw the "phial" type storage and had an idea. But more on that below.
The "phials" are available individually (V4-1) and can be packed tighter inside other boxes
You know that was
exactly the thought I had when I saw them, but I wasn't able to find the "phials" sold separately - now that I know the correct model number I've been able to turn up a few sources,
like Farnell for example. This could well be
the perfect option for storing SMD passives. As I've said many times, and will continue to do, the
Raaco "Handy Box" storage units are frikkin brilliant:
- They lock together both vertically and horizontally, and can be carried around by a handle on top - also while stacked.
- The four service cases each one holds won't slide out while carrying them (or when moving house!).
- Each individual case has a handle as well - so if you only need screws, just bring the screws
- There's a huge number of inserts available; from tiny half-height ones to almost half a case.
- You can populate the cases partially with inserts if you want to store outsize items.
- The inside bottom is ridged, which keep the inserts in place even when one has been removed.
- It's great to be able to take out individual inserts with just those things you will be using.
- They come in many different colours, so you'll know where each one belongs in the stack.
- Both cases and individual inserts are available in ESD safe versions.
- They are made in Europe, Denmark to be specific, and the quality is great - yet they won't break the bank.
Seriously, they're the best thing ever - I use mine to store everything from nuts and bolts to batteries, glues, soldering tips, flux and paste, fuses, shrink tubing, cable ties, blank PCBs, wire, drills, taps & blades, tissues, picks, pins, brushes, and of course all my electronic components, switches, displays and connectors. The stack of four pictured on the first page of this thread weighs a ton, but they handle it without bending or wobbling - sturdy enough to sit on if you need to! To give you some idea of the density you can achieve, I store the E12 series (10-1M) of 1/2W through-hole resistors (0207) - 100 of each value - in
one such case, and I still have room for a tray of mixed power resistors in there as well. Magic.
So naturally, I would love it if I could use these for storing SMD parts as well! I currently do actually, but the gap between the lid and the inserts is big enough that parts
may will escape if you shake it about a bit. HOWEVER, using the "phials" we're talking about here it would be possible to stack a yuuuge number of SMD parts in these cases quite safely. Aaaand it would be possible to use a mixture of different containers, so power resistors could be kept in the same tray as regular ones, and electrolytics with MLCCs, and so on. It would even allow you to mix SMD and through-hole in the same case if you were thus inclined. There's just one thing that worries me: will one of those tiny "phials" (vials!?) hold 100 pcs of 0805 size parts? I think not. Has anyone seen (slightly) larger versions somewhere?
