Hey all. I'm working on a circuit that will allow for switched 12V or ground, as well as a high impedance off state. The end goal is to be able to use this in general purpose automotive circuits, 15-20A continuous. Given that, I'm assuming I will want some sort of snubber circuit, or at the very least some higher power rated diodes between the output and the 12V and ground rails.
Any pointers are greatly appreciated!
