I have two folding solar chargers:
1. Instapark Mercury 10 -- 10 Watt dedicated USB charger
2. Powerfilm F12-750 -- 12 Watt 15.4V charger
When I connect the Mercury 10 to my electronic load at CV (5V) I get 1.0 Amp of current (5W) and this is the most I can reliably push out of this. However, when I connect my Powerfilm charger via a switching buck converter (8-24V to 5V USB) to the same e-load under the same lighting conditions, I get 0.5 Amp (2.5W) at CV 5V. This is in line with what my devices charge at when I plug them into this USB port. However, I can switch the e-load to CC 1 Amp and get the same 1A@5V output of this solar panel this way.
Obviously my solar panel is capable of outputting more power than it is. Does anyone know what I could do to fix this? Would a MPPT charge controller do the trick (or is this just for ensuring against overcharge of lead-acid batteries)?
Thanks!
