Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Solar Panel charger for a Arlo Pro using a BQ24650 and set up converter
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solar Panel charger for a Arlo Pro using a BQ24650 and set up converter (Read 1002 times)
TrueYears
Newbie
on:
May 12, 2018, 11:23:45 pm »
Hello guys!
I have a small project and could use some much needed advice on where to go next. I have with me a 3W solar panel (7.2v .41A) and would like to know if I could use this to charge a NetGear Arlo Pro security camera. I did some research and found that the BQ24650 could be a great cheap solar charger however I need help finding a way to boost the voltage to 9V and current to 1.1A ( this is what the Arlo battery charger outputs)
A typical Arlo official charger cost about $79 dollars and I realize with the parts I would buy it will ended up costing even more but it’s a small project I want to do. Anyways I’ll update this post with new information I find but any help is much appreciated. Thank you for reading.
Source links:
http://www.ijeijournal.com/papers/v2i3/H02035962.pdf
http://www.ti.com/lit/an/slyt424/slyt424.pdf
Logged
mtdoc
Super Contributor
Country:
Re: Solar Panel charger for a Arlo Pro using a BQ24650 and set up converter
Reply #1 on:
May 12, 2018, 11:55:45 pm »
You can’t boost voltage and current simultaneously. That would be free energy!
IOW you can’t get 9.9W from a 3W solar panel.
Logged
TrueYears
Newbie
Reply #2 on:
May 13, 2018, 12:35:13 am »
Hmmm so I could also make it work at 5v at 1.8A you’re right I guess I am just gonna have to built a battery bank then use that to charge the Arlo
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
