Everything looks good, just 1 thing to remember, even though your are are using opto-isolators, the output side where you will be connecting and disconnecting the load, when the relay is off/open, if the voltage between to 2 pins exceeds the maximum 60v, you will still potentially fry the opto-isolator's output. Since I don't know the rest of the circumstances of your circuit, you may want to add 2 back-2-back 50v zener diodes to prevent the voltage gap from exceeding the 60 volt maximum.
As for the 5 amps per channel, as stated above, you may need some cooling if you have a small case with something like 10 5 amp channels mounted side by side.
This may add up to a lot of power as well, make sure your PCB had an adequate thickness of copper, not just trace thickness, but the actual copper clad thickness on the PCB.
