Author Topic: Some PLL help if you please  (Read 1740 times)
Offline JVRTopic starter
« on: August 25, 2014, 11:48:49 am »
Hi Gents, so leading on from this topic, I now need a PLL that will take a sub 100KHz input at a ~7% duty cycle, and give me an output north of 5Mhz with a 50% duty preferred.
I've looked at the old school 4046, but it can output a max of 1Mhz, I'm also looking at the SN74LS297, but I'm unsure what it will think of the low DC input signal. I cant seem to find any modern PLL chips that will take a <1Mhz input signal, and I'd much prefer not to have to cascade the chips.
So please, ye gods of high speed circuity, help a brother out.
Thanks!
JVR
Offline fcb
    • Electron Plus
Re: Some PLL help if you please
« Reply #1 on: August 25, 2014, 12:41:04 pm »
Use a 74HC4046 - good for over 10MHz
Offline David Hess
  • DavidH
« Reply #2 on: August 25, 2014, 05:39:15 pm »
Or use the 4046 with an external VCO.
