It is a 3-band equalizer circuit, with sweepable mid ranging from 350 hz to 5 khz. the low cut is fixed at 100hz
So the idea is to add a switch to change the bass freq, from 100hz to 80hz or something like that.
Im requesting a little help to mod this Eq, im not quite understanding the circuit. Are that 2 33nf caps responsible for the low freq cut?
thanks
