I am working on a project whose goal is to acquire sound ranging between 5 Hz and 5,000 Hz.
The problem is high levels of noise in my sound acquisition setup, leading to poor SNR especially in the low frequency range (below 200 Hz).
The setup I am using is:
1. 50 mV/Pa condenser microphone, PCB 378B02:
http://www.pcb.com/products.aspx?m=378B022. National Instruments 9250 C-series module:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/2146343. National Instruments CompactDAQ 9181 one-slot chassis, Ethernet output
4. Windows 10 laptop running custom-built LabVIEW application
Please find attached several power spectrum density (PSD) measurements and a WAV recording that present the issue.
Screenshot 1: The NI 9250 is connected to the PCB 378B02 condenser microphone (via 1.5 m cable)
Screenshot 2: The NI 9250 is connected to a 1.5 meter BNC cable, unterminated
Screenshot 3: The NI 9250 BNC input is terminated with a BNC 50-ohm terminator resistor
WAV file: A sound recording taken with the current setup. Note the "hiss" in the recording. There is also low-frequency hiss or rumble, which is best heard using over-the-ear headphones or loudspeakers (not laptop speakers).
Notes on measurements/recording:
- the measurements and recording were taken in a quiet room (not an anechoic chamber)
- IEPE current of 2 mA was used throughout
- Sampling rate of 25.6 kS/s was used throughout. Increasing the sampling rate up to 102.4 kS/s did not improve the SNR.
- The NI 9250 was chosen due to its low input noise density: 90 nV/sqrt(Hz) at 10 Hz and 40 nV/sqrt(Hz) above 1 kHz. (Source: NI 9250 datasheet, page 12:
http://www.ni.com/pdf/manuals/378009a_02.pdf)
Questions:
1. How to remove the low-frequency "noise spike" seen in screenshot 1? What is causing the noise spike?
2. Do I need an amplifier in the signal path, between the microphone and the NI 9250? What amplifier would you recommend?
3. Can you please offer any examples of sound acquisition setups with good SNR between 5 Hz an 5 kHz? What microphone-amplifier-data acquisition setup would you recommend? What would be some jellybean devices that people use for this kind of application?
I realise my questions may be quite basic. Please excuse my inexperience with sound acquisition/audio electronics.
Any tips or resources are much appreciated. Thank you!
