Hi guys,
for a project I need a module or a block that can supply a (preferably isolated) voltage (adjustable (preferably electronically) within the range of 300 to 400 VDC) at 1 Amp. The input should be 48VDC. Do you know of such a device? I've checked with VICOR and TRACO and the closest they've got is a MASSIVE (2kW+) overkill or full custom design.
Thank you,
