I use LTSpice nearly all the time. I've tried TINA but I didn't really like it. I don't know why, I just prefer LTSpice, although it was awhile ago since I used anything else.
If LTSpice isn't running, then it's most likely a Windows problem. I've found it crashes more often under the pile of poo known as Windows 10, more than any other OS, including Linux, which runs it under WINE (a Windows compatibility layer) rather than natively.
Does TINA run under WINE?
