I have run some tests with the AQZ205 (100V 2A), AQZ207 (200V, 1A) and with my own back-to-back MOSFETS.
I placed the SSR in series with a 100R load and applied 82V AC pk at 200KHz. The voltage was applied for 1 sec and had 1 sec pause. The LED of the SSR was disconnected. I then examined the amplitude leaked voltages on the load.
1) The AQZ205 (rated 100V), which is what I have been using all this time, immediately got too hot to touch, and let through around 40V pk on the load!
2) The AQZ207 (rated 200V) let around 9V pk through and was cold to the touch.
3) MY own back-to-back MOSFETS connected to the VOM1271 also let around 9V pk though, and did not get hot at all. I also shorted the Gate and Source to see whether it would make a difference and it did not.
I think therefore that the MOSFETs used inside the AQZ205 suffered a voltage breakdown and let the current through and that's why they also get hot. That is my theory.
The AQZ207 is much better but at 1A capacity is too close to my nominal load, I do not trust it either.
So the best solution is the custom made SSR comprised of the VOM1271 and two MOSFETs in this case the IRFSL4615PBF (150V / 33A)
Akis, do you realize SSRs always include an RC snubber network in parallel with the triac?
What kind of voltage drop is acceptable in your switch? How about a single MOSFET in a diode bridge?
Since your switching rate is so low, how about transformer isolated coupling of an AC drive signal, rectified for gate drive. Perhaps cleaning up the gate drive edges using one of the cheap 'power fail detect' 3 pin ICs.
No triacs on these SSRs, they are all MOSFET types. They are made to switch from very small to large AC waveforms without distortion.
The transformer idea is great I had not thought of making my own SSR this is my first attempt, but what's wrong with the VOM1271 ?
