Thanks @ David Hess, thats great info, i wish i had more on that issue of failure in tantalums, and when that failure may occur....we are not allowed to put components in to our lamp PCB that have "lifetime" issues...so Electrolytics are disalloweed for us....if we can proove that the tantalums will not fail in 20 years say, ( (2500 hrs of night time useage per year) then thats great.
Tantalum capacitors are electrolytic capacitors also. They just do not have the lifetime operating limits that aluminum electrolytic and polymer electrolytic capacitors do.
Tantalum capacitor reliability is a complex question. Surge related failures *only* occur when charging so in a current limited application like yours with the capacitor on the output of a switching power supply, this is not an issue. High voltage tantalum capacitors suffer from "field crystallization" around dielectric defects according to NASA but this is a long term problem and I think it only becomes an issue when combined with surge related failures.
Ripple current rating is likely to be the largest problem with a switching power supply especially if a low output capacitance is used so pay particular attention to this. You may need to use a larger capacitor to get a high enough ripple current rating.
Other than that, voltage derate the tantalum capacitor by at least 33% for higher reliability. 50% would be even better. The thicker dielectric layer make self healing more reliable. Consider a premium high temperature and high reliability part.
One trick for high reliability is to burn in the solid tantalum capacitor at its full working voltage *after* soldering. Temperature cycling during soldering causes stress fractures which "reset" the infant mortality part of the reliability curve. Burning in the capacitor at its full working voltage forces self healing and weeds out defective parts.
