Another laser phenomenon that may have been a contributing factor - http://www.chem.scphys.kyoto-u.ac.jp/nonnonWWW/watanabe/studies/photophoresis/index.html.en
Getting motivated to start experimenting.
Any one got a van de graff generator I can borrow?
No, but I do have a 0 to 200KV regulated power supply. SouthWest Sydney area.
I've been trying to get around to setting up the Faraday cage it needs around it (to be safe to use in my small workshop) so I can try some experiments related to something else (that LED sparkle ball thing from another thread.) The cage will be soon; I'm not doing anything fancy, probably just chicken wire (ha ha very appropriate.)
What occurred to me to try, related to your laser scenario, is to put two sphere electrodes spaced JUST far enough to not ark over in air. One of them with a small hole through it, so a laser can be shone between the two at closest distance. So, a relatively short distance, like 6 inches to a foot will do for the experiment. 200KV - can do.
The idea being if the air gap is only just not quite arcing, then any tendency of the laser at all to initiate an arc actually will. If it does, the spheres can be moved apart till nothing happens. That will show what degree of effect the laser has.
Only guessing about mechanism, but if it does work I think it will be due to the laser stimulating photoelectric emission from the surface, (in the high E field). Excess ions near a point on the surface will accelerate in the field, and form a leader cascade 'point', concentrating the field more as the leader point extends. Possibly with the laser beam assisting further ionization at the point, since there there's a zone where the air is reaching breakdown point anyway, and any extra energy (the photons) will kick it over. So there'll be a kind of guiding effect. The laser couldn't do it by itself, but it can steer the much greater energy available in the electrostatic field.
I'd guess it will only work in E field gradients not far below arc-over levels.
Your moving film/paper might build up charge to just below arc-over level, but self-limit there due to volume corona effects draining the charge before it gets to breakdown at any point. Until someone shines a laser at it...
