The manufacturer of this product has abraded off the number of this SMD-8 switching device.
It's in a 2-LED flashlight, one flood and one spot. Pressing the latching pushbutton once turns on the flood LED. Pressing the pushbutton again turns it off. If it is pressed again within a few seconds the spot LED illuminates; if the pushbutton is not pressed within that time period, pressing it again turns on the flood LED again.
Based on the delay between successive "ON" presses of the pushbutton, the device enables one of two outputs, turning on one or the other LED.
The only cap is in parallel with a resistor creating this time constant.
Anyone know what part number this switch device might be?
Schematic of the circuit follows. (Transistors--A13sHB--are draw intentionally vague; don't know if they're BJTs or FETs. Anybody know?) Power is a single 18650 cell.
Thanks.
