Hi Folks -
I have a little "power ORing" conundrum and I'm curious: how do sync buck converter behave when asked to sink current? I'm sure this is largely controller specific so I'm looking at the LTC3621 (integrated switches) in particular.
http://cds.linear.com/docs/en/datasheet/3621fc.pdfMy first guess was that it would try to regulate by keeping the bottom (NMOS?) switch activated, essentially dumping the inductor to ground (effectively "shorting" the regulator output to ground). However in reading the datasheet closer I'm not so sure (because it's partially regulating on inductor current as well as FB voltage). Especially interesting is in the section describing the "burst mode":
"Thus, when the switcher is on at relatively light output loads, FB voltage will rise and cause the ITH voltage to drop. Once the ITH voltage goes below 0.2V, the switcher goes into its sleep mode with both power switches off. The switcher remains in this sleep state until the external load pulls the output voltage below its regulation point."Does this mean I can safely present a higher voltage at the output of the inductor? For my project I'm looking at the switcher (output variable between 4.5-7.4V) facing a potential fixed 7.5V.
Another thought was that the regulator would "fall out of regulation", and perhaps I can finagle the PGOOD pin with the RUN to shut the regulator down? But then there's startup...hmm.
Thoughts?
Happy wiring,
Jamie
