Author Topic: ANALOG TO DIGITAL CONVERTER FOR INDUSTRIAL APPLICATIONS  (Read 701 times)
Offline cRash1001
  • Country: np
« on: January 08, 2017, 05:44:00 pm »
I have been using R1SE-0505/H2-R for isolated power supply for ADC MAX1300. I was told that using the R1SE for power supply will be same as just using a LDO to supply the ADC. So, what would be better to supply power to the ADC a low noise LDO or isolated power through R1SE-0505/H2-R? Inside R1SE-0505/H2-R is a transformer with some components for oscillation.
Offline kiran_shrestha
  • Country: kr
  • Kiran
    • shorted wire
Re: ANALOG TO DIGITAL CONVERTER FOR INDUSTRIAL APPLICATIONS
« Reply #1 on: January 09, 2017, 01:36:56 am »
No.. you should use small LDO after R1SE because R1SE output is not so good for ADC... I have tried it... by the way are u making isolated current sensing...hahah.. just wondering...
Thats all
The following users thanked this post: cRash1001
Offline cRash1001
  • Country: np
« Reply #2 on: January 10, 2017, 01:47:30 pm »
Kiran bro, its me ditish. Its actullly for industrial application, probably for to work in conjuction with PLC or something. So, its better if just use a low noise LDO instead of R1se?
  • Country: kr
  • Kiran
    • shorted wire
« Reply #3 on: January 10, 2017, 05:17:18 pm »
I though so ..  ;D as I have bought R1se long before.... R1SE is isolator and u can use LDO after it and run adc in low voltage 2.8 or 3.3 as R1SE has output is 5V for 5v input.
Thats all
