@KE5FX,
No these are taken with the Faxitron MX-20 cabinet system. The AEC seems to set the voltage to 31kVp in most cases and just adjusts the exposure time. I will be playing with manual setting of the voltage and duration in due course as I found that I could produce better images of challenging DUT's that way. (using my older Bioptics camera MX-20)
The Gendex sensor area is small in comparison to that of the MX-20. The USB DC12 MX-20 has a 120mm x 120mm sensor area and the DUT is moved closer to the X-Ray Generator in some of my images in order to provide magnification. None of my images have been digitally magnified, but that is also an option with these highish resolution 4MP images.
The Gendex sensor is still winging its way to me from the USA. It cost me $100. It is not working but includes the important calibration file. I thought it worth the risk, and I will learn about it whilst carrying out a repair (if such is possible)
The Gendex sensor is a more limited device in that, even though it is Size 2, it is quite a small imaging area. This is offset by decent resolution. Size is sometimes not so important when dealing with imaging a small PCB, or part of a larger PCB. I personally like having a larger imaging area as it is more versatile. The down side is that the large Hamamatsu digital X-Ray cameras cost a small fortune new, so are less common on the secondary market. For me, this 'new' USB Faxitron with DC12 camera is about as good as I could wish for, and meets my needs perfectly. Its so fast at taking an image (around 30 seconds per image, depending upon DUT)
Fraser
