I just picked up some (10) peltier modules from Amazon (see link) as I have a project that needs some cooling and I just received them. I did a quick test to see if they worked and which side was hot and which was cold so I fired up my Tekpower power supply as it can do a bit more than 5A at a bit over 30V. I set it to 5.2A, the max setting and 12V and tested all ten pieces I'd received. The first one I tried drew no current so I tested with the leads reversed -- no current. OK, not a good start. The next one powered up just fine and I was able to tell, very quickly, which side was hot and which side was cold and marked it with an H and a C. I tested the rest of them and all told 3 of them were DOA while the other 7 appear to be functioning as they should.
The meager specifications on the Amazon page indicates the following:
Size: 40mm x 40mm x 3.8mm
Voltage : 12V
Umax (V) : 15V
Imax (A) : 4.3-4.6A
QMax (W) : 72W
Power Cord : 300mm
Net weight : 22g
Color : White
https://www.amazon.com/gp/product/B00K67XZF4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1I found that the temp on the hot side got hot real quick and I didn't want to run them without a heatsink on the hot side so I grabed one of the heat sinks I picked up for the project -- they're 50mm x 50mm x 20mm and are therefore a bit larger than the 40mm x 40mm modules. I put one heatsink on the cold side and another on the hot side then powered back up again with the idea of running longer and getting a feel for how hot and cold it would get with the heat sinks. After just a couple minutes the hot side heatsink was quite noticably warm bordering on hot and the TC contact probe indicated 65C (150F) at a voltage and current of 12.5V and 2.4A with the current going down from a high of about 2.6A at first power.
OK, so I have a few questions about these modules and about the best method for using them. First, increasing the voltage didn't seem to cause an obvious increase in current so I have to wonder if going above, say, 12V gains any cooling effect or if it only results in more heat on the hot side. Second, would it be wise to use thermal paste between the module and the heatsink and if so is there a particular type of thermal paste that's recommended? Lastly, while it's easy to calculate the power consumption from the voltage and current delivered is there a good formula that one can use to calculate the heating and cooling power and how that is effected by voltage?
Brian
