Think about what a type k thermocouple is and what will happen when you solder it.
If filling a lug with an epoxy or something similar, there is thermal inertia to contend with. This could help to average things out. It really depends on your application and what you want to see.
If you want to measure rapidly changing temperatures, then you want as little thermal mass as possible.
