If you are on a magnetar then looking will probably not be high on the list of things, as you will be stripped of the iron in your blood at incredible speed, and the assorted particles you are made of will be sorted by paramagnetic value, irrespective of what they originally were atoms of. It literally will be happening faster than the impulses can travel to your brain and be decoded into an image and comprehended by the brain.
Being at the epicentre of a nuclear blast ( as in right next to the outer casing) would happen slower.
