Hello everyone,
I'd like to pick your expertise on inductors in the output low-pass filter of a DC-DC regulator scenario.
Is there any difference / advantage in using thru hole vs smd inductors? I DO produce high quality square wave that's being fed to LC but after the inductor I experience some instability. The circuit does not get hot, nor the interference is produced by the load. I'm set to operate around 500-600kHz and I draw up to 3.5A off my design. That makes inductor's current ~3.5A rms and ~4A peak. My calculations point to minimum ~6uH.
Back of an envelope: 5uH + 50uF -> ~10kHz
Now. At a first glance the answer is simple - as long as the parameters of the part are the same - there is no difference, right? Egh... but real life is some apart from theory. That's why I'm asking for a quick look in your history of experience. Is "add 30% above what you calculate (inductors have 10-30% tolerance) and you should be fine" the end of it?
Before anyone asks - yes, I did build the PCB circuit and already testing the measurements in it's target environment. And yes, I am using low ESR cap.
At this moment I'm more working on improving the design then making it work.
Thanks for your input.
Patrick.
