That's why i asked help here!
Sorry,
If your only requirement is "space saving photocoupler available at RS" then you cannot expect any useful answer.
So what are your requirements (isolation voltage , switching speed, current ...)
Usually the isolation voltage determines the package area which is necessary.
with best regards
Andreas
Hi Andreas and thank you for your answer.
I didn't say this "space saving photocoupler available at RS"!!!
Actually i said;
"Does somebody know a TIL111 equivalent but with the 4x optos in one soic smd package?
( If possible available in RS, since it's the place where i buy my components )"
So the requirements are equivalent to TL111, and "if possible" available on RS, not mandatory.
On my search i found one part that can fulfill my requirements, but i need to test. It's a toshiba, don't recall the reference, because i'm not at home.
