Author Topic: Tracing underground electrical wiring - Metal Detector or Other Means?  (Read 39720 times)
Offline IanB
Oh boy 11kV under load makes a nice bang.
I believe so. I remember a case in Letchworth where a cable fault under the pavement made a bang that rattled shop windows and lifted the paving slabs.
Offline MinerMini
Re: Tracing underground electrical wiring - Metal Detector or Other Means?
« Reply #26 on: December 06, 2017, 06:41:12 pm »
Anyway, you should try! I'm not a specialist, but my friend tells me a lot about metal detectors and their use. The most simple and informative article is here - http://tenrows.com/metal-detectors/ , and honestly the only one that i've understood
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #27 on: December 06, 2017, 10:31:10 pm »
For those who are interested this is the sort of cable that's usually used for direct burial in the UK:
There's a lot of paper insulated, lead covered still in use for distribution, along with the more modern XLPE insulated stuff.
For the OPs problem I would probably either hire a cable tracer or just dig at the end to see what direction the cable is going and see what can be deduced from that - cable runs are usually pretty straight. Most commercial cable tracers inject modulated 33 kHz and then look for that, a few rely on the cable re-radiating broadcast LW signals.
