I've got a transformer with several taps on the primary side that will be unused. What's the best practice to do with the unused ones? I'm guessing just leaving them unconnected and cover with heat shrink, but best to ask first.
In case the "primary side + multiple taps" creates confusion ... what would the answer be if the secondary side had multiple taps, with some unused?
The primary windings in question are: two sets of 0 - 110 - 120 Volt windings. Only the 0 - 110 Volt tap of each will be used, and put in series for 220 Volt total on primary side. And as you may have guessed, the secondary is 220 Volt as well. To be used as an isolation transformer.
