Author Topic: Transmission Line Avalanche Pulse Generator  (Read 86572 times)
Offline Jay_Diddy_BTopic starter
« on: January 26, 2013, 02:22:36 pm »
Hi Group,
I would like to share some details of a Transmission Line Avalanche Pulse generator that I built.
The challenge is to try and generate a flat-topped waveform.
Here is a 4ns pulse being displayed on a Tektronix 7104 1GHz oscilloscope.
The rest of the story is in the pdf document attached.
Jay_Diddy_B
« Last Edit: January 26, 2013, 02:24:24 pm by Jay_Diddy_B »
The following users thanked this post: rodd, Andie, graybeard
Offline muvideo
Re: Transmission Line Avalanche Pulse Generator
« Reply #1 on: January 26, 2013, 04:36:22 pm »
Nice, thank you for sharing, it's always fascinating
the exploration of such high speed events.
I had success using a STC945, but since I'm cheap,
I built a simple discrete step-up for the power supply :)
The pulse profile I obtained was similar to yours,
but slightly longer at 10nS total, I was limited by
my plugin speed:
http://www.flickr.com/photos/14336723@N08/7248441944/#
Fabio.
Fabio Eboli.
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: January 26, 2013, 06:39:53 pm »
Good show old man ! ( quote from the addams family movie )
As i need to send out the PCB for the JW pulser this weekend i will adapt it so it has a transmission line on it. don;t know if it will work... i already had the layout adapted so it only uses traces ont he top. so i can use the bottom side of the board to do the wave guide.
i recalculated and will use 25 mil track with 8 mil gap . don't know how long i will be able to make the track ... i'll do the layout so that you can solder the 1 meg resistor into te classic layout or solder it into the waveguide and 'dot' the other end ento the ring around the collector
(see the JW pulse generator topic here)
Offline CarlG
« Reply #3 on: January 26, 2013, 07:14:45 pm »
Nice work & good report!
Offline BravoV
  • +++ ATH1
« Reply #4 on: January 27, 2013, 10:20:17 am »
Thanks for sharing this, and what a bunch of nice scopes you got there !  :-+
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: January 27, 2013, 11:31:06 am »
if no abberation there, the rise time should be around 400ps guesstimating from my eyeball.
edit: i agree to prolonge the ON period to greater than 10ns minimum, so there's no dispute on rise time for slower DSO. at 4ns pulse, a 100MHz DSO will not reach max volt reading by the time the pulse is going down.
« Last Edit: January 27, 2013, 05:46:48 pm by Mechatrommer »
alm
  • Guest
« Reply #6 on: January 27, 2013, 04:15:19 pm »
Which is about right for a 1 GHz scope. You would need a sampling scope to properly characterize this circuit.
Offline tinhead
« Reply #7 on: January 27, 2013, 04:56:44 pm »
i did similar efforts, finally ended up with 2m of RG316, based on AN94 version http://www.linear.com/docs/4183
My results are so far ok, you can compare to your TDS700 pics to see the difference.
EDIT: i'm using Mini Circuits 20db attenuator between the pulser and scope to optimize the damping.
« Last Edit: January 27, 2013, 05:00:30 pm by tinhead »
« Reply #8 on: January 27, 2013, 05:56:44 pm »
I am working on a new version. The new version will have a pre-trigger so that I can use my Tektronix SD-24 sampling head in an 11801A  mainframe. This is a 20GHz scope. The sampling scope requires a pre-trigger.
I have an attenuator built in to my board.
I hope to have some results later today.
Stay tuned ....
Jay_Diddy_B
« Reply #9 on: January 27, 2013, 11:54:36 pm »
I am going to share some preliminary pictures and test results. I will take some better scope shots when I am finished.
The results were measured with a BFR505 transistor. The BFR505 will avalanche with around 30V.
The scope shots were taken on a Tektronix 11801 scope with a SD-24 sampling head. This combination has a bandwidth of 20GHz and a risetime of 17.5 ps  :-+
Blank Board component side:
Blank Board solder side:
Rise time timebase 200ps / div. Measured risetime is around 100ps
Full pulse at 2ns / div
It will be interesting to see if the waveform cleans up when I put in all the 'Z' wires. Have left them out because I want to experiment with them.
Photograph of the assembled board, all the important stuff is the lower left corner.
Photograph showing the SMD transistor
Component side. The 74HC14s are used to generate the pre-trigger timing.
I will share more details later.
Jay_Diddy_B
« Last Edit: January 27, 2013, 11:59:48 pm by Jay_Diddy_B »
« Reply #10 on: January 28, 2013, 02:42:32 am »
Hi Group,
I have done a little more work. I have installed about 1/2 of the 'Z' wires that connect the top and bottom ground planes. I have also taken some scope shots with some other scopes.
Tektronix TDS 754A 500MHz Bandwidth
Tektronix DSA602A with 11A71 Plugin 1 GHz
These were taken with a Tektronix 11801 and SD-24 sampling system. 20 GHz BW , 17.5ps RT.
I have also attached the schematic in pdf format.
Jay_Diddy_B
« Last Edit: January 28, 2013, 02:44:37 am by Jay_Diddy_B »
Offline tinhead
« Reply #11 on: January 28, 2013, 03:42:49 am »
mixed feelings ... yours looks like Figure 11 in AN94, where my compared looks like Figure 13. The rise time difference (71ps) is "huge", these scopes are normally good up to ~600MHz, these 735ps are in my opinion not good enough.
Offline mazurov
« Reply #12 on: January 28, 2013, 03:45:25 am »
JDB,
I can't find a ferrite bead noted on a schematic. I'm trying to google 'we74279203'. Could you please share the manufacturer/model?
Thank you,
Oleg.
With sufficient thrust, pigs fly just fine - RFC1925
Offline tinhead
« Reply #13 on: January 28, 2013, 04:12:08 am »
WE is "Wurth Elektronik", simply search for number
« Reply #14 on: January 28, 2013, 07:18:04 am »
for mazurov:
The Ferrite bead is from Wurth Electronik. Some of these parts are available from Digikey. This part is very similar
Digikey 732-1602-1-ND
The bead is not super critical.
for tinhead:
My risetime has not been peaked. I don't have a capacitor on the collector of the transistor, only the transmission line. It opens up a much bigger question as to why the risetime on an oscilloscope looks the way it is.
If a scope had a single pole at the bandwidth frequency then the waveform would look exponential.
Oscilloscopes have been engineered to have a Gaussian Response.
Here is a SPICE model of a Gaussian Filter
The reponse in the Frequency Domain
The response in the Time Domain
One of the properties of the Gaussian filter is that as you reduce the risetime on the input the risetime on the output reaches a minimum. After this point the risetime on the output becomes fixed.
HP made some Transistion Time limiters based on this property. The model numbers are 15432 through 15435
Link http://www.home.agilent.com/en/pc-1000000488%3Aepsg%3Apgr/transition-time-converters?nid=-536902323.0.00&cc=CA&lc=eng
What is interesting about this, is that the waveform from my pulse generator looks flater on a low bandwidth scope than it does on a higher bandwidth model.
The bottom line is that you should not see overshoot unless the input is overshooting.
Is there a Gaussian Conspiracy ?  :-//
Jay_Diddy_B
« Last Edit: January 28, 2013, 07:22:16 am by Jay_Diddy_B »
Offline jahonen
« Reply #15 on: January 28, 2013, 07:26:05 am »
Jay_Diddy_B
Isn't a Gaussian filter supposed to be like cascaded RC instead of cascaded LC?
Regards,
Janne
« Reply #16 on: January 28, 2013, 08:26:30 am »
This application note from Picosecond Pulse Labs discusses the Gaussian Filter.
http://www.picosecond.com/objects/AN-7a.pdf
By strict definition the filter I implemented is 'near Gaussian' I modelled the G10 filter as described in the Picosecond app note.
Jay_Diddy_B
Offline tinhead
« Reply #17 on: January 28, 2013, 12:17:16 pm »
The rise time of this pulse generator is in ps range, this is where a typical digital scope respond flat and not gaussian anymore
http://cp.literature.agilent.com/litweb/pdf/5988-8008EN.pdf
therefore, and this is my opinion and why i've set damping in my generator as i did, it does not make sense to "cut" the signal to match gaussian response.
« Reply #18 on: January 29, 2013, 11:32:52 am »
 It is a very interesting application note from Agilent. It basically say that oscilloscopes fall into two groups Gaussian and Flat response. They present the argument that the Flat Response instruments will give more accurate risetime measurements.
The essential difference is that in the Flat Response instruments the analog front end does not restrict the bandwidth, and an anti-aliasing filter dominates the response of the instrument.
The application note references Infiniium 58400 series of oscilloscopes. So I did a little digging into the specifications. This is what I found:
This suggests that only the top of the line 2.5GHz 54846A is flat response. All the other members are Gaussian.
I also looked at the Tektronix TDS520 manual. I believe that all the 500MHz TDS scopes have similar performance, but I might be wrong. And this is what I found there:
These specifications and the second formula provided by Tektronix suggest that the Tektronix TDS 500 series are in fact Gaussian.
It is also interesting to note that the risetimes are not measured directly, but calculated from the bandwidth measurement.
Jay_Diddy_B
« Last Edit: January 29, 2013, 11:44:00 am by Jay_Diddy_B »
Offline tinhead
« Reply #19 on: January 29, 2013, 11:16:00 pm »
right, TDS500/600/700 belongs for sure to Gaussian response group, the newer series TDS2000/TDS3000 as well.
TDS7000 should be however Flat response model.
I did some measurments of TDS700(with 250MHz LPF enabled) and Tekway TDS1202B -> this is a chinese DSO, with 200MHz BW. It seems to be as well in flat group, from the values it does match Butterworth. The same input stage is being used in lot of chinese DSOs, another example is Rigol DS1102e (all these Rigol hardware clones made by ATEN and Siglent).
It could be insteressting to see, properly measured, frequency respond of Rigol DS1102E.
« Last Edit: January 29, 2013, 11:38:05 pm by tinhead »
Offline PA4TIM
« Reply #20 on: February 01, 2013, 12:44:44 am »
http://www.pa4tim.nl/wp-content/uploads/2010/11/calibratiescoop.png
Picture of bandwidth test using a sinewave. The Rigol DS1102E is included.
Online Mechatrommer
  • Country: my
« Reply #21 on: February 01, 2013, 04:42:03 am »
can you post it at https://www.eevblog.com/forum/reviews/frequency-response-of-your-dso/ including the excel file? whats the relation between dBmV, mVtt, mV rms and dB columns? noob question here i hope you can reply in that thread, thanks.
« Reply #22 on: February 03, 2013, 12:15:13 am »
Hi Group,
I have been busy adjusting my Transmission Line Avalanche Pulse Generator. Here are the latest results:
Picture 1 - Measured with Tektronix SD-24 in 11801 mainframe 20 GHz sampling scope.
Full pulse 1ns/div
Picture 2 - Measured with Tektronix SD-24 in 11801 mainframe 20 GHz sampling scope.
Risetime 200ps/div
Picture 3 - Measured with Tektronix SD-24 in 11801 mainframe 20 GHz sampling scope.
Risetime 100ps/div
Measured risetime is 82ps  (light travels 25 mm in 82ps, a signal on the board about 17mm)  :-+
Picture 4 - Measured with Tektronix 11A71 plugin in DSA602A. (1GHz BW)
risetime 200ps/div
Picture 5 - Measured with Tektronix TDS754A 500MHz scope.
risetime 500ps/div
Measured risetime is consistent with measured bandwidth = 340 / .568 = 619 MHz.
Construction
The important area:
I have attached a pdf file of the schematic
Jay_Diddy_B
« Last Edit: February 03, 2013, 12:17:54 am by Jay_Diddy_B »
Offline krenzo
« Reply #23 on: February 03, 2013, 12:59:44 am »
Jay, you can use this program to get screenshots from your 11801.  I use it with my 11801B and a serial-to-usb cable.  I have the source code if you're interested.
« Reply #24 on: February 03, 2013, 01:21:20 am »
Krenzo,
Interesting!!
The screenshots from the DSA602A are generated by a program that I wrote to convert the Tektronix bitmap file to TIF files. My DSA602A does not have the latest firmware in it.
I was planning on doing the transfer electronically, but for now I use I use a floppy. The 11801 does not have a floppy, so I used a camera. I was going to use GPIB with a prologix adapter. It is not very often that I use the 11801. It is not a very good general purpose scope.  :D
I will look on the back and see if it has RS232.
Many thanks !!!
Jay_Diddy_B
Offline tinhead
« Reply #25 on: February 03, 2013, 02:55:41 am »
now it looks perfect, good job!
Offline marshallh
    • retroactive
« Reply #26 on: February 03, 2013, 05:23:33 am »
Very nice captures and pictures. Thanks for sharing.
Verilog tips
BGA soldering intro
Offline muvideo
« Reply #27 on: February 03, 2013, 08:53:01 am »
Very nice result!
Do you have an idea about how sensitive is the pulser
behaviour to the particular transistor or pcb?
Just to understand if it's easily reproduced,
I updated my "todo list" with your pulser :)
It will be a nice playground for learning to use
old sampling scope plugins.
Could you post the layout, if you did already,
sorry, I've missed it.
Thanks,
Fabio.
Fabio Eboli.
« Reply #28 on: February 03, 2013, 10:40:25 am »
I believe that the layout is relatively insensitive to the board material. This is based on using a calculator on the coplanar waveguide. The properties of the coplanar waveguide seem to be dominated by the gap between the trace and the ground plane. This why I chose coplanar waveguide over stripline.
I used standard FR4.
The layout seems critical. To remove the ringing on the pulse I used a Tek SD-26 in the TDR mode to look for impedance discontinuities.
By far the bigest improvement came from removing this thin ground track in the attenuator section.
The BFR505 was not selected. It was manufactured by NXP and bought from Digikey.
The next step would be to buy some proper end launch SMA connectors and make a second one.
Jay_Diddy_B
« Last Edit: February 03, 2013, 10:42:39 am by Jay_Diddy_B »
Offline mrflibble
« Reply #29 on: February 03, 2013, 11:30:28 am »
Stupid question: why was that trace there in the first place? As in, what would it's intended function be?
« Reply #30 on: February 03, 2013, 03:02:48 pm »
Mechatrommer is correct. I just did a copper pour in the design of the pcb with the spacing set at 20 thou. I have a lot of experience at moderate frequencies, but I am new to GHz+ frequencies.
To me this is a learning excercise.
Jay_Diddy_B
« Reply #31 on: February 07, 2013, 12:58:40 pm »
Hi Group,
All the previous scope photographs that I have posted were made with a BFR505 transistor.
I have now swapped the transistor with the MMBT2369A, this is the SMD version of the 2N2369A.
Here are the new pictures:
These pictures were taken with a 20 GHz scope (SD-24 in 11801).
Regards,
Jay_Diddy_B
Offline mazurov
« Reply #32 on: February 07, 2013, 11:36:00 pm »
It is strange that this transistor avalanches that slowly. I have a pulser made out of 2N2369A in TO-18 and it's about twice as fast.
Another strange thing is that top is ramping up.
Offline mazurov
« Reply #33 on: February 12, 2013, 10:15:50 am »
I built BFR505-based pulser and here are my results. I'm using 1m of good quality coax generating ~10ns wide pulse. Rigid cable gives better pulse but the longest piece I have is 6in. It seems that 20ns pulse width is the limit  for BFR505 - first 3 lasted about 10 minutes, I had to stop since I only have 2 left. 10ns seems to be safe.
The 200ps screenshot shows the risetime of 7a29p amplifier which is about right.
Next step is going to be wiring a pre-trigger from S-52 and check the risetime with 7S12 sampler.
« Last Edit: February 12, 2013, 10:20:22 am by mazurov »
« Reply #34 on: February 12, 2013, 10:44:25 am »
Hi mazurov,
What repetition frequency are you using?
What is the voltage of the power supply?
I did my testing at 20kHz.
I will be interested to see the results from the 7S12. Which sampling head do you have?
Regards,
Jay_Diddy_B
Offline mazurov
« Reply #35 on: February 12, 2013, 11:01:34 am »
This one self-avalanches every 16.6 uS, so about 60KHz. The power supply is at 53V.
I have S-6 and S-4 heads, will try both. The biggest question is whether 800ps risetime 1V pre-trigger pulse from S-52 will be enough to trigger the transistor.
« Reply #36 on: December 10, 2013, 04:39:38 am »
Hi Group,
With the low cost of having boards made by itead, $15.00 for 10 boards 5 x 10 cm, I have modified my design to fit on a 5 x 10cm board.
I order the new boards about two weeks ago, I have been tracking them. I will probably get to try the new boards on the weekend.
Here are pictures of the new board:
Jay_Diddy_B
Offline mazurov
« Reply #37 on: December 10, 2013, 04:54:42 pm »
Are you planning on selling some of the boards?
Offline nctnico
« Reply #38 on: December 10, 2013, 10:28:23 pm »
If that serpentine trace is supposed to be a matched impedance trace then the clearance is way too narrow.
« Reply #39 on: December 10, 2013, 10:35:48 pm »
its not the impedance. This thing is a long capacitor.
one thing that concernsme is i don't see an opening in the soldermask... that's going to leak...
« Reply #40 on: December 10, 2013, 11:33:15 pm »
The dimension of the transmission line are the same as the line that was used to generate this pulse:
I used this calculator:
http://chemandy.com/calculators/coplanar-waveguide-with-ground-calculator.htm
I am also concerned about having solder mask on the line. I realized this after I sent it out. I will have to what happens when I get the boards back. I can always try scraping away the solder mask  :(
Jay_Diddy_B
« Last Edit: December 10, 2013, 11:34:52 pm by Jay_Diddy_B »
Offline BravoV
  • +++ ATH1
« Reply #41 on: December 11, 2013, 02:14:17 am »
Let me guess, precision scraping using the Protomat ?  >:D
« Reply #42 on: January 02, 2014, 02:50:21 am »
Hi group,
I am ready to share some results obtained from the new version of the board made by itead.
TDR Testing
A Tektronix SD24 sampling head was used in a Tektronix 11801 Mainframe. The SD24 has specified reflected rise time of 35ps.
Test setup:
The board was connected to the SD24 with a short length of semi-rigid coaxial cable.
The attenuator on the board was shorted. The avalanche transistor was also shorted collector emitter. This allows the transmission line on the board to be measured with the TDR.
TDR Results
The step rise is the start of the pulse. The first aberration is the SMA connector on the SD24. There is a smooth section which is the 100mm length of semi-rigid cable. The next group of aberrations is the SMA connector, R7 and Q1 components. After this is the transmission line on the board. There are small aberrations corresponding to the bends on the transmission line.
It can be seen that the transmission line on the board is a close match to the 50 Ohm coax.
Pulse Testing
In order to get the best pulse shape I had to play around with the attenuator located on the PCB. Originally I had a single 20dB attenuator. This did not work very well. There was a very fast spike on the output corresponding to a fraction of pF in parallel with the resistor. I split the attenuator into two 6dB sections. I also found it was necessary to add a matching network.
Here is a picture of the attenuator section:
Here is a picture of the pulse generated:
The rise time is around 60ps  :-+
Jay_Diddy_B
« Last Edit: January 02, 2014, 02:52:40 am by Jay_Diddy_B »
Offline BravoV
  • +++ ATH1
« Reply #43 on: January 02, 2014, 05:24:35 am »
Thanks for sharing, damn ... 60ps  :o , so the solder mask doesn't give you any trouble  ?
Offline jahonen
« Reply #44 on: January 02, 2014, 08:23:14 am »
The effect of the solder mask is that it makes the impedance slightly lower and is more lossy than air. But the effect is quite negligible in this case. However, produced pulse looks somewhat like that FR4 dielectric and skin effect loss is becoming visible (tilting of rising edge near flat top). That is not surprising considering the edge speed. I wonder, would this benefit of considerably better substrate, like teflon or Rogers etc.
Also, since edge speed is very fast, there might be some non-TEM waveguide modes which cause distortion on the edge even if the impedance match is perfect.
Regards,
Janne
« Reply #45 on: January 02, 2014, 11:26:21 am »
Hi Janne and the group,
I did a little reading on TDR measurements. Tektronix has a nice document 55W_14601_2.pdf
Link: www.tek.com/dl/55W_14601_2.pdf
In this document there is this formula which gives the relationship between the reflection coefficient and the impedance:
The Tektronix 11801/SD24 makes this easy by giving a cursor readout of the impedance.
I have one cursor on the semi-rigid coax and the other cursor on the straight section of the coplanar waveguide. The measured impedances are 51 and 47 Ohms respectively.
If I move the second cursor to the bend on the coplanar waveguide, the measured impedance drops to 46 Ohms as shown in this measurement.
The impedance is slightly lower than 50 ohms. This could be due to the solder mask as suggested by Janne or the dielectric constant of the FR4 is not 4.7 as used in the calculation.
I also believe that some loss is visible in the TDR measurements.
I am sure that using an RF substrate instead of FR4 would give better results. I am also sure that building the high speed attenuator from ordinary 0603 and 0805 ($0.002) resistors is not the best. The idea is to try and see what you can do with ordinary parts.
It is quite remarkable that the Tektronix SD24 TDR is able to measure these discontinuities. The SD24 had a MRSP of $17,875 and the 11801 was about $20K (1990 dollars).
Jay_Diddy_B
« Last Edit: January 02, 2014, 11:32:38 am by Jay_Diddy_B »
Offline DL8RI
« Reply #46 on: January 02, 2014, 11:45:04 am »
Yes. With this signals you are far beyond the capabilities of FR4. I have never characterized FR4 up to this Frequency therefore I can't give you any numbers, but the tan-delta and permitivity will be quite off. I'd suggest you try some Rogers-Material or go for a semi-rigid-line instead of the CPW.
« Last Edit: January 02, 2014, 11:47:44 am by DL8RI »
Offline nctnico
« Reply #47 on: January 02, 2014, 05:31:22 pm »
The fiber glass weaving in the FR4 is probably also visible in the TDR trace. For circuits running at several GHz on FR4 it is recommended to have the traces run at 45 degree angles to even out the impedance differences caused by the fiber glass.
« Reply #48 on: January 02, 2014, 07:24:36 pm »
I am not experienced enough at these high frequencies to know if it is the fibre glass weave. I do know that more exotic materials are normally used for these frequencies.
At the self-generated frequencies the effect is not visible.
Is anybody aware of a place that will make boards using Rogers material at a reasonable price? The few places I looked wanted a lot of money.
I also looked for some SMD attenuators. I found these Susuma ones on Digikey:
Link: http://www.susumu-usa.com/pdf/products_38.pdf
I don't think that they are really good. Any alternatives?
Jay_Diddy_B
Offline marshallh
    • retroactive
« Reply #49 on: January 02, 2014, 07:34:33 pm »
I was wondering if the impedance changes in the coplanar waveguide section were caused by glass weave (I don't think so, since each 6 bends was clearly defined and consistent) or by a non-TEM mode. How would routing the turns as 45 degree beveled right angles instead of arcs affect that?
I remember reading just a bit ago somewhere, maybe PCB-Pool, doing a pool of Rogers (or was it alumnium?)
Verilog tips
BGA soldering intro
Offline jahonen
« Reply #50 on: January 02, 2014, 08:01:26 pm »
Howard Johnson states that even making perfectly rounded corners does not mitigate the excess capacitance (lower impedance regions!) at the corners. To mitigate the effect, one must remove much more material. That explains why in many microwave PCB's there are quite chamfered corners, but they are still 90 degree ones:
Layout professionals often point out that modern layout systems already round off all the outside corners, assuming that this rounding eliminates the square-corner effect. It doesn't. Rounding the corners removes 21% of the copper in the corner. Edwards[1] shows that you must remove 70 to 90% of the copper from a right angle bend to neutralize (to first order) the excess capacitance. Rounding removes only a small fraction of the required amount of copper. Rounded-corner right-angle bends work well in digital designs not because they are rounded, but because the corners are too tiny to cause significant problems in the first place.
[1] T. C. Edwards, Foundations of Interconnect and Microstrip design, 3rd ed.,John Wiley & Sons, 2000, ISBN 0-471-60701-0
Regards,
Janne
Offline jscm2000
  • Country: cn
« Reply #51 on: March 02, 2014, 01:08:37 pm »
????1ns??????????????
Offline G0HZU
« Reply #52 on: March 03, 2014, 12:19:19 am »
Interesting thread...
I can only suggest PCB places in the UK that deal in laminates like Rogers for small qty. I expect that they deal worldwide though.
Very local to me is Trackwise in Tewkesbury.
http://www.trackwise.co.uk/
We sometimes also use Labtech but I haven't used them for a few years now.
http://www.teledynelabtech.com
I'm pretty sure they are still based in Wales. For large qty multilayer PCBs with Rogers on the outside and FR4 inner layers we use Graphic or Exception but these places will be very expensive even for a basic Rogers board.
I can mill Rogers boards here at home on a T-Tech Router but not to the accuracy you need. I can normally mill track widths to about 1-2 thou accuracy but it isn't guaranteed and it sometimes takes a few attempts. I think you have a milling machine as well so I guess this isn't an option.
Have you tried simulating the meanders on something like Sonnet EM? you can probably do it with the free trial version as I think it allows up to 32Mb these days if you register for the free trial upgrade to 32Mb.
http://www.sonnetsoftware.com/
I can't advise on the precision SMD attenuators as we tend to use fairly average spec ones for SMD use.
Note: It's worth asking about etching tolerance for Rogers boards. Labtech are pretty good at getting low tolerance. We sometimes need ultra high accuracy in the PCB for things like notch filters in the GHz region or simple microwave BPFs. The more expensive places like Exception or Graphic are the top choice for this though. They can also advise on what they think the characteristic impedance will be of the finished GCPW transmission line.
« Last Edit: March 03, 2014, 12:32:37 am by G0HZU »
Offline G0HZU
« Reply #53 on: March 03, 2014, 07:32:00 pm »
I had a look at what SMD attenuators we have in our system and the usual suspects are either Barry or MiniCircuits.
The GAT range from Minicircuits are quite good and they are very small and cheap. But they aren't really what I would describe as precision attenuators.
http://217.34.103.131/pdfs/GAT-20+.pdf
The other option is to stick with SMD resistors and choose to make your attenuator using resistor values that have parasitics that can hopefully mimic a lossy transmission line when placed on your PCB.
The best behaved resistors in 0805 package tend to be in the 100 to 150 Ohm range as their impedance stays faithful up to the higher frequencies and you can make a pretty decent attenuator if you make up the values using combinations of these resistances. But the PCB will spoil this a bit once you place the resistors down on it and you may need to do some subtle matching to get very low return loss up at a few GHz.
Also, when asking about etching tolerance it's best to specify the copper weight because the available accuracy from the PCB maker probably won't be the same for different copper weights on the Rogers Laminate.  I tend to use Rogers 4003C or 4350 here at home on the milling machine. It is very hard on the tools though. Notably more wear compared to FR4.
In the old days (before they closed down) the best laminate for milling was GIL GML1000 as it was very easy on the tools and had decent RF performance. I've still use it as I still have some left but you might be able to buy some cheaply as obsolete stock and mill the board yourself or send out the GML1000 to a PCB place.
You can get it in 0.02" or 0.03" or 0.06" thicknesses.
http://www.apcircuits.com/resources/information/gml10060.pdf
« Last Edit: March 03, 2014, 07:45:27 pm by G0HZU »
Online Marco
« Reply #54 on: May 17, 2014, 07:33:55 pm »
Sorry for the necro, but in case you're still reading this ... did you ever run the sampling scope with envelope instead of averaging so you could determine the jitter?
« Reply #55 on: February 08, 2015, 11:43:05 pm »
Hi group,
I spent a little time in the lab today playing with the Transmission Line Pulse Generator. This is the latest version:
The performance can be influenced by the way you build the circuit. This is a picture of the unit I built today:
And the performance, the rising edge, using a Tektronix SD24 in a 11801 mainframe (20 GHz):
and the big picture showing the pulse:
Regards,
Jay_Diddy_B
« Last Edit: February 08, 2015, 11:44:37 pm by Jay_Diddy_B »
The following users thanked this post: Andie
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #56 on: February 09, 2015, 02:32:58 am »
Curious dip, seems to suggest the first... ah what is it... few millimeters? is kind of wonky.
Go figure! ;)
Nice 100ps edge, not bad at all.
Seven Transistor Labs, LLC
« Reply #57 on: February 10, 2015, 02:48:43 am »
Go figure! ;)
Tim and the group,
I determined that the spike on the leading edge came from the potentiometer. It was not really inductance, it was the time that it took for the signal to reach the pot. This was new to me. I found it by setting the pot to 0 Ohms. Those pots have a folded construction inside.
The dip following the peak, I believe is called 'dribble-up'. I am not sure what physical properties cause it.
I have done some fiddling with the circuit to reduce the distortions.
Here is the latest schematic:
A photograph of the output section:
This is the inductor that I used, it has a self-resonance frequency of 3.2 GHz:
These are the latest waveforms:
It has taken a lot of experimenting to get this waveform.
Regards,
Jay_Diddy_B
« Last Edit: February 10, 2015, 02:50:46 am by Jay_Diddy_B »
Offline T3sl4co1l
« Reply #58 on: February 10, 2015, 03:07:53 am »
Yeah pretty much... good luck adjusting anything at this level.  Either it's made perfectly, or it stinks.
Also, this is two layers still?  Probably some of the remaining bumpiness comes down to mismatch between resistors (tiny!) and traces (fat), plus higher order TEM modes in the PCB, or even across the width of the trace.  Without getting really, really involved (many spins, or EM simulations?), going to 4 layer would probably be the next major improvement.
Even the best Tek generators had some residual bumps.  I suppose at that point, you have to wonder if it's the generator, or the scope, or cables, or connectors... or bondwires, or what?
« Reply #59 on: February 10, 2015, 03:21:37 am »
Tim,
I am using 2 layer 0.062 (1.6mm) FR4 boards made by Itead. I am still using the original boards that I made, 10 boards for $15.00 so nothing exotic at all. I scrapped away the solder mask and made some cuts in the copper.
The resistors are standard 5% carbon film that I bought in a binder from eBay. I have been using 0402 and 0603.
The SMA connector that I used on this board is nothing special either some cheap ones that I bought from eBay.
http://www.ebay.ca/itm/10pcs-connector-SMA-male-plug-solder-PCB-clip-edge-mount-straight-M-/281161178633?pt=LH_DefaultDomain_0&hash=item4176831e09
I am not using any cables, I have the board mated to directly to the Tektronix sampling head. The scope may not be perfect, but I can check the scope with 17.5ps rt generators in the TDR head.
I will not try and make any more improvements. I think I will attempt to build a second one the same.
Regards,
Jay_Diddy_B
« Last Edit: February 10, 2015, 03:36:33 am by Jay_Diddy_B »
Offline 3roomlab
« Reply #60 on: October 13, 2015, 01:42:02 pm »
Jay_Diddy_B
i know this is an old thread, i was fiddling with the web calculator, i was thinking what if the whole trans-line was shrunk in size? ( i have zero experience in HF design)
example
Er = 4.2
width = 0.915mm (36mil)
gap = 0.153mm (6mil)
PCB = 1mm
Eeff = 2.696
Zo = 50.99
would shrinking the entire circuit help in improving the overall rise time?
« Last Edit: October 13, 2015, 02:22:00 pm by 3roomlab »
Offline T3sl4co1l
« Reply #61 on: October 13, 2015, 02:12:10 pm »
Rise is largely limited by the switching device, and things immediately around it (lead/bondwire lengths, traces and pads).  As far as I know, ~200ps is characteristic of avalanche physics and device geometry, so you're doing quite well down there.
Better risetime can be had from a step recovery generator, but these are also more tricky to drive (an already fast pulse is needed) and lower amplitude (a few volts? not that you need much).  On the upside, jitter is better.
Offline 3roomlab
« Reply #62 on: October 13, 2015, 02:28:05 pm »
ok so i suppose the "shape" change of the trace/PCB affects something else (like what Jay said in earlier post) the jitter-y-jagged-noise of the output signal? (even if i build this i dont think i will see it properly in action, i have no fast scopes, so its more of a curious question)
Offline T3sl4co1l
« Reply #63 on: October 13, 2015, 02:38:25 pm »
The length of the TL determines the length of the square pulse, and its impedance and dispersion control how flat the pulse is, and what the falling edge looks like (dispersion causes an anomalously slow falling edge, "drool" as it were).  A periodically varying TL (as one might expect from a sinuous trace) will have humps or ripples, the amplitude of which depends on how far off the impedance is.  Rounded or chamfered corners are better than solid square corners.  Even a gradual bend should be reduced in width, slightly.
« Reply #64 on: October 13, 2015, 07:08:13 pm »
example
Er = 4.2
PCB = 1mm
Eeff = 2.696
Zo = 50.99
The challenge with making the transmission narrower, is manufacturing tolerances. You can check what happens if the gap is 5mil, 6mil or 7mil.
Free-Electron in his variation used a narrower transmission line than I did.
https://www.eevblog.com/forum/blog/eevblog-306-jim-williams-pulse-generator/msg186193/#msg186193
I do not have free_electron's version to test in my lab. My fast scope (20 GHz) requires a trigger pulse at least 40ns in front of the pulse that you are looking at so I could not test this version anyway.
Regards,
Jay_Diddy_B
Offline Kalvin
  • Embedded SW/HW.
« Reply #65 on: October 13, 2015, 08:10:49 pm »
Jay_Diddy_B,
Did you perform any tests or simulations what would happen if the ground areas around the transmission line was removed or pulled away from the transmission line considerably so that the EM-field would be almost completely confined between the transmission line (top layer) and the ground plane (bottom layer). To me it seems that the ground areas with the patched vias might reduce pulse quality.
For example, using the transmission line calculator http://chemandy.com/calculators/coplanar-waveguide-with-ground-calculator.htm with the following parameters
4.2
3.3 mm
5 mm - 10mm
1.5 mm
will give Z0 48.91 ... 50.43. Also, the tolerance to the track width is quite good. For example varying the track width between 3.1mm ... 3.3mm changes Z0 between 52.84 ... 48.54 (gap width = 10mm).
« Last Edit: October 13, 2015, 08:28:26 pm by Kalvin »
« Reply #66 on: October 13, 2015, 08:26:05 pm »
Jay_Diddy_B,
Did you perform any tests or simulations what would happen if the ground areas around the transmission line was removed or reduced considerably so that the EM-field would be almost completely confined between the transmission line (top layer) and the ground plane (bottom layer). To me it seems that the ground areas with the patched vias might reduce pulse quality.
Kalvin,
There different kinds of transmission lines used on circuit boards.  There is microstrip which is a single trace over a ground plane. The width of the strip is determined by thickness of the board and the dielectric constant of the board. For a given board there is only one width of trace for given impedance.
I used a construction called co-planar waveguide. In co-planar waveguide the gaps between the strip and the ground plane influence the impedance. You can choose the width of the trace and vary the gap to keep the impedance constant. You can also make tapered sections to go from one width to another width.
There is also stripline where the conductor is between two ground planes.
I checked the impedance of the line using a TDR with 17.5ps rise time. With this TDR I can see impedance discontinuities in mated SMA connectors.
https://www.eevblog.com/forum/projects/transmission-line-avalanche-pulse-generator/msg358382/#msg358382
Regards,
Jay_Diddy_B
Offline Kalvin
  • Embedded SW/HW.
« Reply #67 on: October 13, 2015, 08:35:39 pm »
Jay_Diddy_B, thank you for the explanation. I removed my comment about the pulse quality as the ripple is quite modest. The tolerance to the track width seem to improve when the construction is towards the microstrip.
Offline 3roomlab
« Reply #68 on: October 14, 2015, 02:10:01 pm »
i put together this based on Jay's PDF. im not making the project cos i have no fast scopes to "calibrate", so i am just mucking around with creating eagle PCB layouts and schematics. i am interested to know if i am in the right ballpark esp on the transmission line and the entry point of the SMA (i editted the footprint so that it is all similar width to the 39mil 50ohm trace throughout, does this make sense?) pls ignore the incomplete via stitching for ground plane. this size of the board is based on the popular 2inchx2inch, and it seems it is also possible to fit in a LT1073 power supply on the flip side left corner.
instead of the OSC in the PDF, i am toying with a 6 gate schmitt trigger as oscillator and R-C phase shifting it to get different rising edges. (or maybe not, schmitt trigger have large performance drift?)
i can see the length of the transmission line at approx 20320mils long, i dont suppose there is any harm if i make it even longer?
(edit, while trying to find some reading material, i saw this PDF called corners-japan, which tells of some interesting experiments about right angled traces)
« Last Edit: October 15, 2015, 04:19:47 am by 3roomlab »
Offline T3sl4co1l
« Reply #69 on: October 14, 2015, 07:31:24 pm »
Mind that there will be a very slight amount of coupling between side-by-side traces (very little, with the ground plane filling in the gaps, but it might be discernible on a faster scope?), and the bends have a lower impedance on account of the way the fields distribute across the width of a curve (the velocity is effectively faster on the inside corner), which also contributes some dispersion (falling edge 'drool').  Being in FR-4, it'll also be fairly "drool-y" due to the dielectric properties.  Which you can't really do much about, aside from perhaps an R+L (or a more complex network of some sort) at the termination.
Speaking of networks, I suppose the rise/fall time could be very slightly improved (no more than ~2x in the limit) by adding a small C or R+C in parallel with one or more of the output attenuator (series) resistors.  That might be worth trying, I mean, if you had a scope to play with of course.  (Nothing you'd bother with on the initial layout -- the extra pads would do as much to screw with the response as you'd be trying to fix.  But it's something that can be tried by stacking chip components, a perfectly cromulent prototyping approach.)
So, for what it is, it's fine, and unless you have over 1GHz of scope bandwidth to hand, you probably won't be able to tell the artifacts in the first place!
Offline juani_c
  • Country: ar
    • ssihla
« Reply #70 on: December 31, 2015, 12:46:29 am »
In AN94, figure 8, the charge line is shown with an open end. Is that "charge line" similar to this "Transmission Line"?
Does the Transmission Line need to have an open end as well? I can't see that in the schematic.
I don't know much of Transmission Lines, sorry if this is a stupid question.
« Reply #71 on: December 31, 2015, 03:14:19 am »
The terms 'charge line' and 'transmission line' have the same meaning in this context. It could be described as a charged transmission line.
The open end of the transmission is connected to resistor that is used to charge the transmission line. From a fast signal point of view, the high value resistor is an open circuit.
The circuit works by first charging the transmission. The charged transmission line is then connected to the output attenuator using an avalanched transistor. The transistor switched in this way is very fast.
The length of the output pulse is twice the electrical length of the transmission line. The speed of the propagation in the transmission is very close to the speed of light for an air line, slower for a transmission line with plastic or epoxy insulation.
The circuit makes a pulse that has a flat top. You need the flat top if you want to measure the rise time of an oscilloscope.
Regards,
Jay_Diddy_B
Offline daiguangming
  • Country: cn
« Reply #72 on: February 05, 2018, 06:41:08 am »
hi group
way i rise is not fast ?use ztx415
« Last Edit: February 05, 2018, 07:01:15 am by daiguangming »
Offline T3sl4co1l
« Reply #73 on: February 05, 2018, 07:54:50 am »
I have no idea what's going on with that board there...
ZTX415 is slower (and more powerful), check the datasheet.  Waveform seems more or less reasonable.
Offline Insatman
  • Country: ph
« Reply #74 on: February 05, 2018, 08:46:24 am »
I posted about a charge line pulser with <600ps Trise using a simple 2N2222.  https://www.eevblog.com/forum/projects/avalance-jw-charge-line-pulser-for-step-waveforms-~45v-out/msg1405898/#msg1405898.
A photo of the output waveform below.  More detail in origional post including schematic.
Relatively cheap to build.
Retired Pulsed Power Engineer/Physicist...now I just dabble in electronics
  • Country: cn
« Reply #75 on: February 05, 2018, 12:32:44 pm »
schematic?way fall is slower ?
Offline Insatman
  • Country: ph
« Reply #76 on: February 06, 2018, 02:53:01 am »
The fall is almost always slower than the rise on chargeline pulsers.  You can usually reduce it by putting a resistor from the output of the transistor to ground.  The value of which depends on your particular circuit.  I've found for most 50 ohm circuits that something between 50 and 200 ohms usually works best to shape the falling edge.   I'm sure that better methods exist as well.
Offline ducus
« Reply #77 on: April 27, 2020, 07:14:56 pm »
Good evening
Is there any chance of getting the PCB project? I made a variant with BFR93A built around an SMA plug. The results are satisfactory but not mechanically stable. That's why I would like to build a PCB-like version. Sorry but my English is not very good. I'll be back with photos.
Thanks!
Dan
« Reply #78 on: April 27, 2020, 08:23:30 pm »
I have the Gerber files and the original Orcad 9.2 Files.
There were changes made after the board was designed, especially in the output area:
Regards,
Jay_Diddy_B
Offline ducus
« Reply #79 on: April 27, 2020, 10:13:07 pm »
Super. Can send me an email with both?
« Last Edit: April 27, 2020, 10:16:31 pm by ducus »
Offline ducus
« Reply #80 on: April 27, 2020, 10:18:04 pm »
Ugly construction
Offline ducus
« Reply #81 on: May 01, 2020, 12:52:01 am »
Thanks Jay_Diddy_B.
I did the pcb and i have some results. Scoop is TDS745C hacked to 785C but not calibrated till 1GHz.
« Reply #82 on: May 01, 2020, 12:55:47 am »
Hi Ducus,
Are you in the Southern Hemisphere? Your scope is upside down  ;D
Are you going to share pictures of your board?
Jay_Diddy_B
Offline ducus
« Reply #83 on: May 01, 2020, 01:03:52 am »
I removed attenuators from board because i have lots of ringing and i use my function generator to trigger the transistor. Like this BFR93A avalanche at aproximativ 40V. Without external trigger it will avalanche at 50V. Until now i'm satisfied with results. Next step to finish ground via on the transmision line and if is ok to do an new pcb more clean (this is made in harry with toner transfer).
Regards
Dan
« Reply #84 on: February 25, 2022, 11:27:46 pm »
Somebody asked me by private message for the Gerber files. Here they are. These are the last boards I ordered and if you follow the thread there was a lot of experimenting with the output section.
The .TXT is the drill data.
Jay_Diddy_B
* Jay_Diddy_B_avalanche_PG_gerbers .zip (56.08 kB - downloaded 83 times.)
Offline jonpaul
« Reply #85 on: February 26, 2022, 09:51:27 am »
We use the Leo Bodnar 40 pS pulser, very fine and tiny, designed to check scope RT and aberration. Much faster and better!
Cost L49 UK
http://www.leobodnar.com/shop/index.php?main_page=product_info&products_id=295
Jon
Jean-Paul  the Internet Dinosaur
« Reply #86 on: February 26, 2022, 11:49:02 am »
Jon,
You are right the Leo Bodnar design is better. I shared the files in response to a request from a forum member.
History
The design presented here is around 9 years old. Starting in mid-2012 there was tremendous interest in the Jim Williams pulse generator. At the time people were upgrading the newly introduced Rigol scope and were looking for something cheap to demonstrate the increase in bandwidth. People were turning 50MHz 1052E into the 100MHz 1102E.
Dave produced a video:
and forum member, Free Electron, start what was to become a very popular project:
The Jim Williams pulse generator and the derivatives produced a pulse like this:
In order to measure the scope risetime, you need a flat topped waveform. I promoted the transmission line version at the time.
Free Electron added the transmission to MKII of the unit he designed:
https://www.eevblog.com/forum/blog/eevblog-306-jim-williams-pulse-generator/msg192189/#msg192189
I started with the 2N2369 transistor and achieved risetime in the 200 - 300 ps range.
I quickly changed to using an RF transistors (BFR505) and got into the 60ps region.
It is a neat circuit to play with. You can spend very little money and play around for hours ....
Best regards,
Jay_Diddy_B
« Last Edit: February 26, 2022, 11:50:57 am by Jay_Diddy_B »
Offline rodd
  • Country: br
« Reply #87 on: June 02, 2023, 04:44:21 pm »
Hi folks,
I found this old thread but decided to build the Jay Diddy version of the pulser.
In one of the replies he provided the Gerber files for the PCB.
There had been a lot of changes in the design, all documented in the thread, but one issue has been left open.
In the gerber files provided, U3 is actually a 555 timer, NOT a LTC1799CS5.
C7 and C8 are also missing in the all versions of the schemitics provided untill now.
I consulted Jay_Diddy (in another thread) which promptly provided the "old version" of the schematics used as reference for the Gerber files, which I decided to post here for reference, in case some other person decides to build this project.
Thanks again for Jay_Diddy.* Transmission Line Avalanche Pulse - Nov 28 2013.pdf (28.83 kB - downloaded 66 times.)
