Hello everybody !
I write my first message on this beautiful problem because I have a problem where I am really stuck since few days.....
What I want to make ?For lab demonstrations, I need to made few precision power supply (voltage supply with current limiting). In the best case, current limit will be adjustable but if not, it is ok : this not my priority in this design but I will be great.
All this supply will work for small Laser Diode or LED (actually processed in the Lab).
In fact, I need 3 of them :
+4,5V /+6V with a limit of 100mA
+2V / +5V with a limit of 100mA
+2V / +5V with a limit of 500uA
I plane to just use battery as alimentation. This 3 power supply will be on 3 separate PCBs but I try to made the same topology, so I can only made 1 PCB.
What is my problems ?I did not find how I can make the voltage regulation : I need a LDO because I want decrease the voltange and avoid any peaks (no buck/boost). If I use a LDO and connect my LED, the current is directly linked with voltage and I did not know what I can put between the LDO and the LED to compensate the voltage difference (in the case of the current limiting is activated)...
For the current limiting, I have no idea where I need to put my 2N3904 on my circuit (I know that in my schematic, it is on a wrong place but where is the right place... no idea).
What about the components ?Can you say me what you think about this components ?
I plan to use a LT6650 as a 400mV reference (represent as a simple voltage supply on my schematic) to compare with the current measure on a resistor. This resistor will be measured with a AD8276. As a LDO, I will take the LT3014B for the supply with a current limit of 500uA and the two others with a current limit of 100mA. As a general op amp to drive the 2N3904, I use a simple LT1097.
All answers are welcome !
Thanks a lot,
Dj1312
PS : Sorry if there is a few english mistakes : I am not a native speaker.
