I have one of those turnigy reaktor chargers with regenerative discharge. It allows you to discharge the battery under test up to 20A into the source power supply, as obviously, that power has to go somewhere. However, when using a server power supply (like I do) the regenerative discharge will not work. IS there some sort of circuit I can build using some nichrome "springs" and a fan as a high power resistor, and make it so the charger discharges into that load instead of the power supply, but the power supply does not discharge into the load?
