I made a constant current power supply for an arc lamp, based on a welding inverter design.
24V input, 8A at about 16V output.
Transformer is a 40x25x11 ferrite ring.
Problem is, it's heating up at no load, and is not heating up when loaded.
Unloaded, it consumes about 1A, with the heat going out of the bridge's diodes and fets.
As the thing heats up, it goes closer to 2A.
Does not look like an overvoltage - nothing changes with the secondary disconnected from the rectifier, and there are no overshoots or problems in the bridge itself.
So, is that a problem (it works fine and stays cool under load), and if so, what's causing it?
