Electronics => Projects, Designs, and Technical Stuff => Topic started by: hgg on February 11, 2017, 06:16:59 pm
Hi everybody,
Here is just another UT61E backlight mod but with a twist.
This is the usual obligatory modification for every UT61E owner. :)
I had this project going for some months but never found the time to finish it.
The fact that I had to solder mod wires to the ES51922 was scary enough to stop me every time...
Finally I found the courage to do it and here is the finished product:
https://www.youtube.com/watch?v=_qgVNo_FB4g (https://www.youtube.com/watch?v=_qgVNo_FB4g)
I've designed the circuit and ended up with the following schematic and components :
(https://s5.postimg.org/yzj9f4oyv/Schematic.jpg) (https://postimage.org)
Then I placed an order with Elecrow which I highly recommend since they deliver very decent PCBs
with the lowest prices.
(https://s5.postimg.org/ngjbjebfr/PCB_stack.jpg) (https://postimg.org/image/qamgwudlv/)
I started populating the PCB with all the components and then I remembered why SMD work is not my definition of fun...
Dimensions of the PCB are 2.7cm x 2cm
(https://s5.postimg.org/64iyxyhyf/PCB_Populated.jpg) (https://postimg.org/image/s3pdl5ysj/)
Since I had to solder a single wire on the main IC, that was a nice opportunity to modify the factory disabled
sleep timer and RS232 functionality as well. Which means two wires...
Nightmare! I almost destroyed the multimeter! I soldered two pins together and couldn't remove the solder,
twisted one pin. These pins are extremely fragile! After the proper prayers the mod wires were in place. :phew:
(https://s5.postimg.org/ibmpfinvr/MC_Mod_Wires.jpg) (https://postimg.org/image/fhjk22lpf/)
The RS232 pin had to be cut from the PCB trace:
(https://s5.postimg.org/yp6oyo413/RS232_Trace_Cut.png) (https://postimage.org)
Below are some pictures with all the places I needed to connect all the mod wires:
RS232 connections:
(https://s5.postimg.org/6rriycajr/RS232_Pads.png) (https://postimage.org)
Ground for PCB and LEDs :
(https://s5.postimg.org/flifffxif/Power_and_Ground_Pads.png) (https://postimage.org)
Buzzer Pad :
(https://s5.postimg.org/trt4dk21z/Buzzer_Pad.png) (https://postimage.org)
LED wires connected :
(https://s5.postimg.org/oqlqc6ulj/LEDs_Wire_Connections.jpg) (https://postimage.org)
LEDs were glued in place with Loctite Super Glue GEL. The LEDs are underneath the wires.
(The Gel version is way better than the original.)
(https://s5.postimg.org/qvb5ae2jr/SMD_Leds.jpg) (https://postimage.org)
RS232 wires and IR phototransistor in place :
(You also need to solder an IR Led and a resistor to the supplied serial cable PCB which already
has the options but were unpopulated).
(https://s5.postimg.org/msopp1xt3/RS232_Mod.jpg) (https://postimage.org)
Buzzer wire :
(https://s5.postimg.org/acrzvb4h3/Buzzer_Connection.jpg) (https://postimage.org)
Populated PCB piggybacked on the main PCB:
You can also see the PCB VCC red wire connected to UT61E V+ which is live only when the unit is switched on.
(https://s5.postimg.org/bqjmqm3qf/PCB_Piggyback_Location.jpg) (https://postimage.org)
For the touchpad I used a small piece from a copper sheet 0.12mm :
(https://s5.postimg.org/6qm6iny3r/Touchpad_Copper.jpg) (https://postimage.org)
and below is the finished product :
(https://s5.postimg.org/j3ufbtyef/Finished_Product_(b).jpg) (https://postimage.org)
Power consumption of the piggyback PCB is 30nA when OFF and 8.8mA with both SMD LEDs ON.
Final power consumption of the UT61E now is:
2.38mA in Voltage mode,
2.47mA with RS232 ON,
10.6mA with LEDs ON and
178uA in sleep mode.
All in all I am very satisfied with the upgrade.
The only glitch that it has is, when the backlight is on and you turn the switch only counterclockwise,
it might get a false command and turn the backlight off. Maybe this is because I have not shielded
the purple wire that runs from the small PCB to the copper touch pad.
George.
Hi.
Can you recharge the circuit images?
Thank you.
Here is a link I've created with all the photos : http://ut61e.eu3.org/ (http://ut61e.eu3.org/)
