Related to my question about favorite wire to board connectors:
https://www.eevblog.com/forum/projects/favorite-wire-to-board-connectors-for-power/I'm considering using the Molex power cables you find associated with ATX power supplies for carrying mains power from a power inlet to a PCB. Both the Molex Standard (0.093") and Molex Mini-fit Jr seem to be suitable for this purpose.
The advantages I see are (correct me if I'm wrong on any of these):
- pre-made cable assemblies using 20 - 18 AWG 300V wire
- Molex Standard pins and housings are spec-ed to 250V RMS and 9 A with similar specs for Mini-fit Jr
- pins can be extracted and inserted into alternate housings
- both male and female crimped wires in 8"+ lengths are readily (and cheaply) available
Are there any caveats I should be aware of? The intended application would be to supply mains power to a low voltage DC power supply / transformer, so the amount of mains current carried would be < 1A.
Update: I'm basing the Molex Standard specs on the information available
on this Molex web page. I don't know the part number for the 4-pin housings used with computer power supplies, and perhaps they have different specs.
