Thanks for the replies.
Alex:
Yes it is a power sequencing issue. My application is running at >175degC and the LDOs and controllers that I have tested do not operate within specification at that temperature, or have a thermal cut-out (or are not widely available, TPS7H1201-HT)
If I use a power sequencing chip I still have to disable the PMOS pass transistor without affecting normal operation, i.e. build an "enable" pin into my LDO..
David:
I think I'll work out some values for a p-channel bipolar clamp transistor and see how that goes.
Thanks for your help,
James
