Author Topic: Vanished pbc tracks (just want to share failure pictures)  (Read 1354 times)
Offline Miyuki
  • Country: cz
« on: July 17, 2017, 08:44:58 pm »
Hi
I'm experimenting with design of welding inverter, full bridge topology
Yesterday I have spectacular failure, it was really BIG BANG
It use huge capacitor 4700uF at ~400V with datasheet ESR just 40mOhm so it have lot of pretty fast energy (I buy them cheap as old stock)
It was huge bright flash and stunning bang. When I turn everything off there was no visible damage at first but at second look, just see on your own eyes:
« Last Edit: July 17, 2017, 09:29:57 pm by Miyuki »
Offline alm
Re: Vanished pbc tracks (just want to share failure pictures)
« Reply #1 on: July 17, 2017, 08:57:21 pm »
Is this a case where you should cover tracks in solder for increased current handling capacity? ;)
It was huge bright flash and stunning bang. When I turn everything off there was no visible damage at first but at second look, just see on your eyes:
Eye protection indeed sounds like a good idea.
Offline capt bullshot
« Reply #2 on: July 17, 2017, 09:15:45 pm »
Been there, done that long time ago ...
But your results looks really clean and surgical, congratulations!
Offline Miyuki
  • Country: cz
« Reply #3 on: July 17, 2017, 09:27:58 pm »
In this case tracks worked as a good fuse, must measure transistors, they are not shorted (maybe opened will see), rectifier with PFC boost is intact and continue to work fine
Offline alm
« Reply #4 on: July 17, 2017, 09:43:38 pm »
If the transistors survived, then you are lucky. Failures in these kind of circuits tend to take a whole bunch of expensive power semiconductors with them.
Offline MK
« Reply #5 on: July 18, 2017, 04:25:59 am »
usually expensive power transistors lay down their life protecting the fuse...
Offline hermit
Offline DBecker
« Reply #7 on: July 18, 2017, 05:08:17 am »
Not bullet proof, but a good place to start:
http://www.circuitcalculator.com/wordpress/2006/01/31/pcb-trace-width-calculator/
That's probably not useful here.  These traces didn't overheat from a minor error in design calculations.  They delaminated so quickly that not even a scorch mark was left.
Offline ConKbot
« Reply #8 on: July 18, 2017, 05:59:02 am »
Impressive that there isn't any vapor deposited copper/copper oxide left either. I've put 30awg wire across a photoflash cap bank switched by a chunky SCR (intended for powering a disk launcher) and it left a nice copper colored coating on the binding posts. Perhaps the pcb glue (holding down the copper) vapor cloud pushed the copper vapor cloud away.
Offline marshallh
    • retroactive
« Reply #9 on: July 18, 2017, 02:59:31 pm »
Very impressive, top marks not even a single burn mark!
Verilog tips
BGA soldering intro
Offline alm
« Reply #10 on: July 18, 2017, 03:06:10 pm »
Just nature's suggestion for a change in PCB layout I guess ;).
