I don't know how useful or practical building a variable colour LED light panel will be if it's for photographic use
perhaps as a mood kind of lighting in the home? The photographic kind is difficult because you can't trust what the LED manufacturer claims the colour temperature is so you have to characterise or test them to select.
But, there is the catch. I would like to have Kelvin value, in XYZZ format, like on examples bellow, in attachments.
Any body have any idea how to make that kind of design most efficiently?
Thanks a lot!
This is the million dollar question.
You will notice such commercial light panels are not cheap especially for
professional photographic use. Technically you incorporate a colour temperature meter into the unit but how accurate is it?
Funny there are apps for iphone that can measure light in kelvin but how accurate is it? you can read the theory
but how to make an accurate one? Best is buy a used colour temperature meter like from Minolta or others or brand new it's not cheap either. Minolta has stopped making the meters and a Korean company has taken over
by putting their brand over meters. Check out B&H Photo for such examples. Now to measure colour temperature accurately you need a photospectrometer...check the prices on ebay.
Building colour temperature meters is a closely guarded secret. Also check out chinese copy on Aliexpress. Good luck.
Edit: Actually what the led lighting designer has done is using a look up table via a dac to dial in the kelvin temperature but the main thing is characterising the led eg. at what voltage and current is a given colour temperature but also take into account of aging so the important thing is measuring this colour temperature
accurately and this takes alot of work. As a hobbyist a simple colour temperature meter will do if you are not particular about accuracy. Calibration of photospectrameter uses what is known as a black body reference.
