For a project I'm working on, I need a regulator +7.5V that satisfy two simple requirements LDO & PSRR.
I see, there are lm317 and all 78xx series, that have good PSRR above 10 kHz (-70 dB or so up to 20+ kHz) but not LDO.
On the other side modern mosfet p-channel LDO's that have miserable low PSRR, about -10 dB, some companies even don't publish any data except 120 Hz. And its strange for me, unlike 40 years ago nobody should care much about 120 Hz rejection since almost all power supplies switchable, and PSRR in the sub-MHz range should be primary goal for good properly designed voltage regulator. And I don't envision any obstacle to build fast circuits , since technology step far away from lm317 manufacturing process.
What, inductors makers rule the market?
